Valve stem length 450 wheels #939927
02/28/11 05:38 PM
02/28/11 05:38 PM
MrNormTA Offline OP
MrNormTA  Offline OP
I am reinstalling the 450 steel whells on my T/A this week and would like to know correct length valve stems? Anything particular to note about the way they stick through the trim ring or anything different to be concerned about. Also what lugnuts would be considered correct? Thanks
Re: Valve stem length 450 wheels [Re: MrNormTA] #939928
03/01/11 10:30 PM
03/01/11 10:30 PM
MrNormTA Offline OP
MrNormTA  Offline OP
I'm suprised no one knows anything about this!
Re: Valve stem length 450 wheels [Re: MrNormTA] #939929
03/02/11 12:40 AM
03/02/11 12:40 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
There are several different size valve extensions that were used on Mopars, I don't recall which size was used on T/A's off the top of my head though.
Re: Valve stem length 450 wheels [Re: MrNormTA] #939930
03/02/11 12:43 AM
03/02/11 12:43 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Standard lug nuts on a steelie T/A.
I'll check on the stem and extension.
Re: Valve stem length 450 wheels [Re: FJ5_Fish] #939931
03/07/11 03:55 PM
03/07/11 03:55 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I checked an original wheel and tire combo......The rubber valve stem is the short style - 1-1/4" from wheel face to top of stem with no cap installed.
I think there were 2 or 3 lengths of valve stem extenders available.....need to see if I have any originals to tell you what length for them.
Re: Valve stem length 450 wheels [Re: FJ5_Fish] #939932
03/07/11 05:42 PM
03/07/11 05:42 PM
MrNormTA Offline OP
MrNormTA  Offline OP
Thanks for checking. I had 1 that I thought had the original stem still in it and it measured 1 3/8 in. I figured it had plain lugnuts.
Re: Valve stem length 450 wheels [Re: MrNormTA] #939933
03/07/11 06:14 PM
03/07/11 06:14 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I assumje you can buy these valve stem extentions? if so, where? thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Valve stem length 450 wheels [Re: mopars_1] #939934
03/07/11 06:23 PM
03/07/11 06:23 PM
tboomer Offline
tboomer  Offline
I have an original nos one right here and it measures 1 3/8"..Weren't the 69-71 B and E bodys the same for the stems?
Re: Valve stem length 450 wheels [Re: MrNormTA] #939935
03/07/11 09:24 PM
03/07/11 09:24 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
It may be 1-3/8" - I measured it installed with a so-so ruler....
