Re: Audio Question. What are the best aftermarket speakers
[Re: mymcodebee]
#939880
02/28/11 08:27 PM
02/28/11 08:27 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
It is going to be a matter of personal preference and what sounds good for the type of music you listen to. Best thing to do is go to a couple different car audio stores..(not best buy) and listen to the different speakers with your type of music. I personally like MB Quart, Rockford Fosgate, and JL Audio for the types of music I listen to. For amps, you can never go wrong with PPI, ADS amps though you will pay for them, if you are on more of a reasonable budget give punch amps by rockford fosgate a try.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: GO_Fish]
#939882
02/28/11 11:35 PM
02/28/11 11:35 PM
Posts: 3,287 Dalton, MA
Slipknot440
Dalton, MA
i've had success with keeping my systems a little on the small side as to not burn up the electrical. Currently has a sony head unit (52x4), 2 5.25 speakers up front (200 watts peak each), 2 6x9 jvcs in the back and a knockoff brand 300 watt amp from pepboys and 10" pioneer (700 watt peak) sub in the trunk of my wife's 73 charger. It doesn't bounce the stock alternator around and sounds great and I spent less than $250 to do the whole thing.
I'm trying something similar in my RR, looking at 5" infiniti up front, and RF 6x9's in the back with a 250 watt amp and 8" tube sub. SHould be enough for some thump but not enough to mess up the electrical.
My old bee had 2 15" subs and a 1500 watt amp...it took forever to get the electrical to work correctly..new alternator, voltage regulator, etc
