Caltracs question again... #939262
02/27/11 09:50 PM
02/27/11 09:50 PM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
Since Caltracs have been the topic of discussion this weekend, and I currently have xhd leafs on my 67 Coronet which are in good condition (not sagging) will they work with those or is it necessary to use the mono leafs? After reading the other posts here, it seems you can use them with the mono leafs, super stock springs, or xhd leafs. I know of a couple people who are using them around here with the xhd leafs but haven't spoken to them how they work/not for them.
Should I go ahead and see how they react or...? Quick info about my car: 67 Coronet, 470, dana 60, 4.10, 727, 325 M/T drag radials, 90/10s in front, stock suspension in back. Best time of 11.83 @ 113 and change, consistent 1.65 60'. I'm placing an order for a 9.5" PTC from John Cope next week and am wondering if my existing leafs and shocks will handle the reaction/hook it will have, compared to the 11" PTC I have in it now.
Thanks!!
Re: Caltracs question again... [Re: 67dodge67] #939263
02/27/11 09:58 PM
02/27/11 09:58 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Dave...they work best with monos or worn out 4-5 leaf stock springs. If you are thinking of getting them...I would look for a set of old stock springs
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Caltracs question again... [Re: 67dodge67] #939264
02/27/11 10:15 PM
02/27/11 10:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I swear mine worked better with ss springs then when I went mono springs??
Re: Caltracs question again... [Re: Dodgem] #939265
02/27/11 11:31 PM
02/27/11 11:31 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
work ok on my xhd springs
average 1.58 sixty off the footbrake
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Caltracs question again... [Re: tex013] #939266
02/28/11 12:57 AM
02/28/11 12:57 AM
WI, USA
mopar addict
mopar addict
WI, USA
Tex
That's what I have heard before as well, however I also know they are best when using the mono leaf (or the soft springs as mentioned). I think when I contact John at CRT, I'll see what he thinks... heck, he has been a great help lately, why not!?!
Thanks for the replies!
