Is this a '67 B Body Steering Column #939185
02/27/11 07:16 PM
02/27/11 07:16 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I was just told this column is not a '67 B Body by a potential buyer. Can anyone verify if this is a '67 B Body Power Steering column?
Re: Is this a '67 B Body Steering Column [Re: moparrulzzz] #939186
02/27/11 08:02 PM
02/27/11 08:02 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Did he give you a reason? I need one myself.
Re: Is this a '67 B Body Steering Column [Re: GTX MATT] #939187
02/27/11 08:11 PM
02/27/11 08:11 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I believe he's right. '67 was the first year for the collapsable column, a safety addition that would collapse on impact, instead of shoving the column through the drivers chest. On a 67 (or later), I think you'd find the thick part of the column would be shorter, and lead into a collapsable joint that looks like a stamped box at the bottom, just above where it links into the steering box.
I'll try to get a picture of mine. I can say without question, My steering column looks nothing like that ('67 Satellite).
Re: Is this a '67 B Body Steering Column [Re: StealthWedge67] #939188
02/27/11 08:33 PM
02/27/11 08:33 PM
Indiana USA
DBishop68 Offline
DBishop68  Offline
Indiana USA
Correct 67 unit that has the inner shaft collapsed .
Re: Is this a '67 B Body Steering Column [Re: DBishop68] #939189
02/27/11 08:58 PM
02/27/11 08:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I have a partially dis-assembled 67 B-body column at the shop. I'll take pics tomorrow and post with measurements
Re: Is this a '67 B Body Steering Column [Re: gtx6970] #939190
02/27/11 09:04 PM
02/27/11 09:04 PM
Mansfield,Ohio
Mansfield,Ohio
Well the guy who was wanting this says it looks like his but the shaft below that collar is 7-8 inches longer. He said his is a original power steering car that he is switching to floor shifted.
If I am reading the replies correct this is a '67 column but is collapsed? Meaning it has possibly been in a collision and the nylon pins are sheared inside?
Re: Is this a '67 B Body Steering Column [Re: moparrulzzz] #939191
02/27/11 09:52 PM
02/27/11 09:52 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It could be an A-body column. Just swap steering shafts and you'll be fine. The columns are interchangeable.
Re: Is this a '67 B Body Steering Column [Re: Jim_Lusk] #939192
02/27/11 10:43 PM
02/27/11 10:43 PM
Mansfield,Ohio
Mansfield,Ohio
I know I am being Anal but the outer jacket of this '67 column is larger than my '68. I have no idea if that will interfere with my TTI headers I have sitting here.That would be my luck and they would make contact with the column since it's not a '68..who knows!!
Re: Is this a '67 B Body Steering Column [Re: moparrulzzz] #939193
02/28/11 10:18 AM
02/28/11 10:18 AM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
I thought '67-69 floor shift columns all interchanged, except the bottom bearing was different in some years.
That one is definitely short for power steering - aside from being collapsed, could it be a manual center?
Re: Is this a '67 B Body Steering Column [Re: moparrulzzz] #939194
02/28/11 12:30 PM
02/28/11 12:30 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
the column is a 1967 a-body power steering column
since you have rumblefishes busness card, give him a call and maybe he will make things right ???
good luck
tony
Re: Is this a '67 B Body Steering Column [Re: TONY_DAGOSTINO] #939195
02/28/11 01:12 PM
02/28/11 01:12 PM
Mansfield,Ohio
Mansfield,Ohio
We have talked and he agreed to take it back. He still says its a '69 B Body Column!
Alls well that ends well I guess!!
