Re: Hughes rockers?
[Re: jafr]
#938713
02/27/11 03:39 AM
02/27/11 03:39 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Have you called T&D to see special deal direct to racers? If not try it, it was around $200.00 more for the T&D when I bought mine for my SR heads three years ago I think the SR use the same rocker asemblys as the stock 383-440 motors do Call Summit and see what they tell you on prices and drop shipping them direct from Harland Sharp to you and delivery time
Re: Hughes rockers?
[Re: jafr]
#938719
02/28/11 11:37 PM
02/28/11 11:37 PM
Posts: 914 tn
robnbird
tn
I am having a hard time finding a set of Harland Sharp 1.6 rockers for my Indy SR heads. No one has them in stock and Harland says two weeks to ship, that's what they said two weeks ago also. My other option are the Hughes rockers, I can't afford a set of T&Ds right now. How do they compare to the Harland Sharps as far as strength etc. I am running 280 lb. on the seat and around 700 lb. open.
Whoever you use make sure they are mopar people. I will not use Jegs nor Summitt because they are not Mopar people in my opinion. Now Mancini or Ray Barton, Hughes, and Marsh Mopar Performance , He may have a set in stock. Look him up on the net, he is a great guy.
Re: Hughes rockers?
[Re: jafr]
#938722
03/01/11 08:32 PM
03/01/11 08:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Joe,
i think i can help.
I have been down for a bit with a back injury and a bit slow catching up. I'll call you Wednesday.
Todd
RIP Monte Smith
Re: Hughes rockers?
[Re: jafr]
#938724
03/05/11 11:42 AM
03/05/11 11:42 AM
Posts: 83 Southern IL.
jafr
Southern IL.
I recieved my Harland Sharp rockers Thursday! Talked to Nick at Compu Flow yesterday and he has a set of Smith Bros. pushrods heading my way. I am hoping to make some noise next weekend. This motor has taken longer to put together than anyother, hopefully it wil be worth it. Thanks for all the help guys. Joe
Re: Hughes rockers?
[Re: Lew]
#938726
03/09/11 09:19 PM
03/09/11 09:19 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Harland Sharp's would be the cheapest rocker I would ever think about putting on a cam with those pressures. T&D isnt much more money last time I checked. Id be surprised if you couldnt find a set of those in stock somewhere.. Those are just a stock offset with the SR;s IIRC. A few people to check with Todd Marsh Best machine Dewayne Porter Todd Comp Wedge Muscle Motors Modern Cylinder head
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
