Indy Heads #938418
02/26/11 05:20 PM
02/26/11 05:20 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Can you run Indy Heads on a magnum motor? I am going to buy some aftermarket performance heads to put on my 360 magnum motor very soon .I cannot decide what to buy ,I was going to buy Edelbrock RPM's but was thinking I should Buy better ones while I am at it.That way I want have to upgrade later if I want to go faster.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Indy Heads [Re: D-50] #938419
02/26/11 05:33 PM
02/26/11 05:33 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
With pushrod oiling rockers, it's a bolt-on swap. I'm thinking
early year Magnums still had the oil passage to the head
still but, I don't know for sure.
Re: Indy Heads [Re: D-50] #938420
02/26/11 08:35 PM
02/26/11 08:35 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
before u bolt on indy's those push rods with the kit are ka ka,and if u dont have the td rockers,the ones in the kit are ka ka,so big bucks w indy unless ur only lookin for a 6000 max rev type deal
Re: Indy Heads [Re: fishy340] #938421
02/26/11 09:20 PM
02/26/11 09:20 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks for the info. I think I will go with the cnc ported Edelbrocks. They are supposed to flow around 300 cfm. I guess I will need New rockers and pushrods.
Re: Indy Heads [Re: D-50] #938422
02/26/11 09:23 PM
02/26/11 09:23 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
awesome choice unless ur going the big buck way to kill,my dart had a pump gas sb w eddies,10.80 w a flat tappet cam 3200lbs
Re: Indy Heads [Re: fishy340] #938423
02/27/11 02:07 PM
02/27/11 02:07 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I 360-1 on my '94 magnum block...with flowat 335 cfm..they will be the last one I buy ! I almost boughht the Eddy's....
Dan
Re: Indy Heads [Re: Wedgeman] #938424
02/27/11 02:17 PM
02/27/11 02:17 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I would say buy the Indy's because it's no secret- no matter how fast you are going you WILL want to faster in the future. Might as well do it now rather than later.
Re: Indy Heads [Re: 72demon416] #938425
02/27/11 09:24 PM
02/27/11 09:24 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
well if thats the case get w7,w8, or 9 there better then the indysssssssssssssss
Re: Indy Heads [Re: 72demon416] #938426
02/28/11 08:04 PM
02/28/11 08:04 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Would it be better to just by the heads then buy the rockers and intake from another source instead of the top end kit.
Re: Indy Heads [Re: D-50] #938427
02/28/11 08:52 PM
02/28/11 08:52 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would think so since they come with junk push rods and bolts instead of studs and the rockers leave a little to be desired for sure.
From what i have seen I would get bare castings and get better valves,springs and retainers.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Indy Heads [Re: D-50] #938428
02/28/11 09:06 PM
02/28/11 09:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
the heads and intake are the key,the rest is cow dung,unless its a sm hp motor then there ok i guess
Re: Indy Heads [Re: fishy340] #938429
02/28/11 09:29 PM
02/28/11 09:29 PM
S/ST 3040 Offline
S/ST 3040  Offline
I'm taking the complete top end off of 395" Engine Masters entry to INDY next weekend.
Re: Indy Heads [Re: S/ST 3040] #938430
02/28/11 10:03 PM
02/28/11 10:03 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
You have a message S/ST 3040 !
Re: Indy Heads [Re: D-50] #938431
03/01/11 01:00 AM
03/01/11 01:00 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
The edelbrocks arent even in the ballpark with the Indys. We swapped between the two and the Indys were not as high as mentioned. I ordered the Indy heads and intake with T&D rockers setup for a roller cam from Bob Mazz. and it was under $3000. They made WAY more power than the Eddys. Edelbrocks are good but not comparable...
Re: Indy Heads [Re: DaKuda] #938432
03/01/11 08:31 PM
03/01/11 08:31 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Were both the Edelbrocks and the Indys unported? I am just trying to find out all the info I can.Do you have any before and after E.T.s? Thanks for all the info!
Re: Indy Heads [Re: S/ST 3040] #938433
03/01/11 08:46 PM
03/01/11 08:46 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You are correct. The early roller blocks do indeed still had the oil passage.
