Indy Heads
#938418
02/26/11 05:20 PM
02/26/11 05:20 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Can you run Indy Heads on a magnum motor? I am going to buy some aftermarket performance heads to put on my 360 magnum motor very soon .I cannot decide what to buy ,I was going to buy Edelbrock RPM's but was thinking I should Buy better ones while I am at it.That way I want have to upgrade later if I want to go faster.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Indy Heads
[Re: fishy340]
#938421
02/26/11 09:20 PM
02/26/11 09:20 PM
D-50
North, Alabama
Thanks for the info. I think I will go with the cnc ported Edelbrocks. They are supposed to flow around 300 cfm. I guess I will need New rockers and pushrods.
Re: Indy Heads
[Re: 72demon416]
#938425
02/27/11 09:24 PM
02/27/11 09:24 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
I would say buy the Indy's because it's no secret- no matter how fast you are going you WILL want to faster in the future. Might as well do it now rather than later.
well if thats the case get w7,w8, or 9 there better then the indysssssssssssssss ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Indy Heads
[Re: 72demon416]
#938426
02/28/11 08:04 PM
02/28/11 08:04 PM
D-50
North, Alabama
Would it be better to just by the heads then buy the rockers and intake from another source instead of the top end kit.
Re: Indy Heads
[Re: D-50]
#938428
02/28/11 09:06 PM
02/28/11 09:06 PM
fishy340
LONG ISLAND
the heads and intake are the key,the rest is cow dung,unless its a sm hp motor then there ok i guess ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Indy Heads
[Re: DaKuda]
#938432
03/01/11 08:31 PM
03/01/11 08:31 PM
D-50
North, Alabama
Were both the Edelbrocks and the Indys unported? I am just trying to find out all the info I can.Do you have any before and after E.T.s? Thanks for all the info!
Re: Indy Heads
[Re: S/ST 3040]
#938433
03/01/11 08:46 PM
03/01/11 08:46 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
With pushrod oiling rockers, it's a bolt-on swap. I'm thinking early year Magnums still had the oil passage to the head still but, I don't know for sure.
You are correct. The early roller blocks do indeed still had the oil passage.
