440source timing chain cover
#938042
02/26/11 02:28 PM
02/26/11 02:28 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Any problems with the source tc cover?
Ive got one and dont want to use it, if there is a history of them leaking....If they do leak, where?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440source timing chain cover
[Re: redmist]
#938044
02/26/11 03:16 PM
02/26/11 03:16 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Also you will have grind down your cam bolts a little or they will rub on the cover.
???? How big are those bolts you're using ... the inside depth of the fab'd cover is the same dimension as the stock cover!
I think they use a "minimal" jig when they build these - locating off the pins holes but not bothering with the bolt holes Subsequently the cover distorts when they weld it. The pin holes line up fine but the bolt holes are off and the outer rail doesn't follow the contour of the block like a stock cover does. Its a $100. cover.
[Re: dart4forte]
#938046
02/26/11 10:47 PM
02/26/11 10:47 PM
Von
NE Oklahoma
BTW, Im talking about the stock replacement cover, not an aluminum cover.
[Re: Von]
#938047
02/27/11 02:48 AM
02/27/11 02:48 AM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Ok
