Re: turbo charger and super unleaded gas... is it a must!!
[Re: mxbeep]
#936589
02/24/11 10:52 PM
02/24/11 10:52 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Putting around yes but it will probably "ping" when you open her up.
Mopar to the bone!!!
[Re: 67_Satellite]
#936592
02/25/11 01:04 AM
02/25/11 01:04 AM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Octane "GOOD"
Detonation "BAD"
If you hear pings its probably too late. Melting piston!
Burn no less than 92 octane IMO!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: furious70]
#936595
02/25/11 02:15 PM
02/25/11 02:15 PM
Posts: 1,624 qc
mxbeep
qc
Late model computers will be able to compensate for poor fuel quality. and on the same note you will get more miles per gallon running the better stuff. It will usually out weigh the cost....
While this is true, if there's been any modifications to the wastegate actuation (manual controller, bleed, etc) then the ECU may not be able to compensate. It's only $2/tank for the good stuff, if you were really tight for cash you wouldn't be buying an STi anyway.....
as nothing to do with being tight with cash!!, a few places where i travel do not offer 91 octane.
[Re: furious70]
#936596
02/25/11 02:22 PM
02/25/11 02:22 PM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
No body said anything about modifications... Then all goes out the window.... Who knows if something has been done to the waste gate or timing tables.....
BTW gas is almost 4.00 a gallon here.
[Re: mxbeep]
#936597
02/25/11 07:24 PM
02/25/11 07:24 PM
DaytonaTurbo
Manitoba, Canada
Then fill up before you head out and try to avoid the 87 as much as possible. I would make sure to burn it all up and refill w/ 91 or better before getting on the throttle again.
[Re: DaytonaTurbo]
#936598
02/26/11 10:07 AM
02/26/11 10:07 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I can't say about Subarus but I have no problems with running a turbo mopar with 87 octane all the time as long as the proper intercooler is utilized and boost level is modest.
On my 12 second Daytona that was 15 psi in the summer and as high as 21 psi in the winter.
"I think its got a hemi"
[Re: mxbeep]
#936599
03/05/11 02:42 PM
03/05/11 02:42 PM
Posts: 99 Tuscaloosa, Alabama
speedfreak440
Tuscaloosa, Alabama
http://www.lethalperformance.com/2010-sh...se-of-6-p-28089
Good stuff, I have used it myself, it is not a gimmick like the other "octane boosters" you see at autozone & such. Keep a 32oz. can in the trunk for when you can't get your hands on 91+
[Re: CUUDAK]
#936600
03/06/11 05:12 AM
03/06/11 05:12 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Octane "GOOD"
Detonation "BAD"
Hard to find higher than 91 around here
