Checking tranny without driving - is it possible? #936477
02/24/11 06:27 PM
02/24/11 06:27 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I am going to take a look at a 2001 Dakota R/T with about 85000 miles on it. From what I have read the tranny's on these are pretty weak. The truck is not licensed to be driven on the road right now so I can't take it for a drive. Is there any telltale signs that the trans is going to fail on me?
Re: Checking tranny without driving - is it possible? [Re: dd340] #936478
02/24/11 06:53 PM
02/24/11 06:53 PM
Campbellsport, Wisconsin
Abodysforever Offline
If he wont let you drive it somthing sounds funny.
Re: Checking tranny without driving - is it possible? [Re: Abodysforever] #936479
02/24/11 07:05 PM
02/24/11 07:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just because it's not licensed doesn't mean you can't drive it around the block. Don't buy it without driving it.
Re: Checking tranny without driving - is it possible? [Re: stumpy] #936480
02/24/11 07:35 PM
02/24/11 07:35 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
If I was to buy it I would have it checked by a mechanic but I was just just wondering if I could pre-qualify it a bit.
Re: Checking tranny without driving - is it possible? [Re: dd340] #936481
02/24/11 08:33 PM
02/24/11 08:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd drive it. even if it's down to the end of the street and back. how strict can the cops up north be anyway? are they hiding behind every bush waiting to jump on someone for a minor infraction?
you should also pull the rear diff cover. All R/Ts have the 9.25 axle with 3.92 gears and an LSD. the LSD is notorious for the clips that hold the clutch packs in, falling out, the LSD will still work fine(supposedly they're just in there as an assembly aid), but if left in there, the clips can take out the Ring and Pinion gears.
**Photobucket sucks**
Re: Checking tranny without driving - is it possible? [Re: dd340] #936482
02/24/11 09:16 PM
02/24/11 09:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Put the truck on a treadmill
Re: Checking tranny without driving - is it possible? [Re: DAYCLONA] #936483
02/24/11 09:22 PM
02/24/11 09:22 PM
Kirkland, Washington
Pacnorthcuda Offline
Bad idea....it would fly away...
Re: Checking tranny without driving - is it possible? [Re: Pacnorthcuda] #936484
02/24/11 09:53 PM
02/24/11 09:53 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
