Re: Checking tranny without driving - is it possible?
[Re: dd340]
#936481
02/24/11 08:33 PM
02/24/11 08:33 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'd drive it. even if it's down to the end of the street and back. how strict can the cops up north be anyway? are they hiding behind every bush waiting to jump on someone for a minor infraction?
you should also pull the rear diff cover. All R/Ts have the 9.25 axle with 3.92 gears and an LSD. the LSD is notorious for the clips that hold the clutch packs in, falling out, the LSD will still work fine(supposedly they're just in there as an assembly aid), but if left in there, the clips can take out the Ring and Pinion gears.
**Photobucket sucks**
