speedometer plug on trans #936350
02/24/11 02:21 PM
02/24/11 02:21 PM
West Tennessee
rbstroker Offline OP
West Tennessee
Is there any type of plug or cap available that I can use on my 1968 transmission? I am not going to use a speedometer as it is race only. Thought that it may be possible to remove the gear from the trans and find a screw on cap.
Re: speedometer plug on trans [Re: rbstroker] #936351
02/24/11 02:46 PM
02/24/11 02:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why bother. Leaving the gear in doesn't cause any harm and you don't gain anything by removing it.
Re: speedometer plug on trans [Re: stumpy] #936352
02/24/11 04:06 PM
02/24/11 04:06 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://www.brewersperformance.com/proddetail.asp?prod=SPA%2DPL
Postage would cost more than the part, It is 1.75" deep freezeplug.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: speedometer plug on trans [Re: rbstroker] #936353
02/24/11 11:39 PM
02/24/11 11:39 PM
No info on a screw on cap but Munroes 727 bible states a 1&49/64" freeze plug. On your gram scale (my ten dollar Harbor Freight one works great ) see how many grams you are eliminating going from the alum speedo adapter to a Dorman steel freeze plug
Re: speedometer plug on trans [Re: 64dodge572] #936354
02/25/11 12:12 AM
02/25/11 12:12 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Dan
That's what my JW-built 727 came with there.
Ride eternal, shiny and chrome
Re: speedometer plug on trans [Re: RapidRobert] #936355
02/25/11 06:43 PM
02/25/11 06:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The hole in the housing measures 1.755".
Re: speedometer plug on trans [Re: John_Kunkel] #936356
02/25/11 07:06 PM
02/25/11 07:06 PM
Hartville OH
mini340hemi Offline
mini340hemi  Offline
Hartville OH
I found that a International Scout uses a Torqueflight with a threaded cap on the speedo adapter. They run the speedo from the transfer case. Not sure of the years but guessing 70's and 80's binders{IH}
