Page 2 of 3 1 2 3
Re: Approx. hours for a partial rotieserre resto... [Re: DPelletier] #935976
02/24/11 07:34 PM
02/24/11 07:34 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Typically shops have a minimum of 250-300 hrs just for prep and paint on the exterior body, you're talking about doing the complete underside as well.
You've done restoration work in the past so you should have an idea of how much time it will take to dismantle and strip the shell...
I personally think you're robbing yourself if you quote anything less then 500 hrs...
....and if Alan says 500, you should probably plan on 600!
mine took 600 and I had taken the car apart and got it back as a rolling shell.
Unless a car needs a lot of panel replacement, I just don't see how I could possibly have double the hours into it. And I do all the body work by hand. No air file, don't use a da and so on... just a hand grinding for welds and a larger angle grinder and stripping discs for the paint.
Maybe I'm too critical of the time, I go in the house and grab a can of pepsi, that's 5 mins I'm not charging for
Re: Approx. hours for a partial rotieserre resto... [Re: DPelletier] #935977
02/24/11 07:34 PM
02/24/11 07:34 PM
Cincinnati, Ohio
Challenger 1 Online tonguue
Challenger 1  Online Tonguue
Cincinnati, Ohio
My paint job on my 71 car took exactly 210 hours, that did not include the bottem, inside or motor compartment or stripping. Then I put the car togeather.
There was NO rust repair and very minor dolly and hammer work. Thanks to Marz528, he came by and showed me the finer ways to hammer metal.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935978
02/24/11 07:40 PM
02/24/11 07:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
I think the pressure washer I would need to use to do that would cost more than it would be worth. Still the problem is, even if you could use that, it's not going to remove the rust. I had to blast the excess, scrape with a razor blade then reblast parts... believe me if there was an easier way I'd love to be able to do it.
Gawd I'd love to show you some time, Nope not gonna do a thing for rust repair except make it very easy to lightly media blast it clean after pressure washing and in some cases make it unneccasary to media blast at all before rust repair. Media blast once after all metal work is done.
Pressure washer cost $5800. bucks. It get's used almost everyday for everything one would need to clean. We're on our second one at work and I bought one for myself that I keep at home. The first one at work lasted 21 years.
Most valuable tool I own even though I have stuff that cost more, like machine tools.
Re: Approx. hours for a partial rotieserre resto... [Re: Challenger 1] #935979
02/24/11 07:45 PM
02/24/11 07:45 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
210 hours for that just sounds like a lot to me. I'm kind of shocked by some of the numbers. I really thought I was a slow worker when it came to body work! I'm definetly not cutting corners, I'm blocking the cars more than once... all I can say is I definetly feel alot better about the progress I have made!
Re: Approx. hours for a partial rotieserre resto... [Re: Challenger 1] #935980
02/24/11 07:52 PM
02/24/11 07:52 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I don't do body work, never have, probably never will.
However I've had dozens of cars painted by several body shops over the years...
This is how it was explained to me...
It takes approximately 3 days to take one panel from bare metal to finished paint...
That includes prepping the metal, epoxy prime, filler work, sanding, priming, block sanding, final prime, guide coat, final blocking, paint, clear coat, denibbing, polishing.
That is approximatey 24 hrs labour.
NOW: Most cars have 8-10 panels...2 fenders, 2 doors, 2 quarters, hood, trunk, roof, valances.
Simple math: 8 X 24 = 192 / 10 X 24 = 240
In other words the average car takes 200hrs - 250hrs
Now, if you're thinking that I'm still high...notice I didn't count the engine compartment, door and trunk jambs, trunk floor, any special attention to sound deadener, etc...etc...AND I haven't even considered doing anything to the bottom of the car....
I stand by my estimate of 500 hrs
CHECK OUT MY NEW WEB SITE !
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935981
02/24/11 08:19 PM
02/24/11 08:19 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
500-600 hours for sure. To what extent are you going?? A basic job may be 300 hours BUT:
Are you but welding everything & finishing off both sides? Are you putting lead back where it goes? Are you putting back all the proper sized spot welds? Are you mocking up everything that can change body gaps AFTER the car is assembled? Are you putting drip in the primer on the floor pan & bubbles in the floor pan where it pools?
There are certain things that should be bolted on that stress the cars body/doors etc. I have no surprises me when I'm done. This stuff takes time but you get a killer job when it's finished!
Plus some guys are naturally quick at some jobs, but bodywork is one thing that will come back to bite you if rushed!
Re: Approx. hours for a partial rotieserre resto... [Re: Paul Jacobs] #935982
02/25/11 02:55 AM
02/25/11 02:55 AM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I see where your coming from Alan. Although I think that number would be on the high side for parts that just need stripped, primed, blocked painted... but I guess as a general number that could be about right.
As far as the extend of making it original, this car is going to be more of an over restored car which the underside being shiny and not with the factory runs, over spray and so on. There were no panels replaced, just some small patched on the trunk and one quarter. As far as bolting on panels and linign everything up, yes to all that. I'm not sure I'm fast at it as much as it's been a pretty easy project compared to most. Now replacing panels and such, that I would say I can do quickly. I have as much experience doing collision work as anything and that part I always found easy.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935983
02/25/11 01:44 PM
02/25/11 01:44 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Well the crowd has spoken and the message seems to be fairly consistent. People like Paul and Alan do this stuff every day. Any big variances you are getting are due to two things only;
- differences in scope
- differences in quality
I'm sure you are doing a quality job so any differences would be scope related. In my case my bodyshop may have spent 10-15% longer as they aren't mopar specialists and I had to do most of the research and explain it to them......but at the end of the day, I'm confident that I got what I paid for and it was well over 500 hours. Of course every car is different as is every resto.
What I'd be interested in from some of the participants on this thread is how long do you think a total restoration goes? EVERY nut, bolt, bodywork, paint, mechanical systems, machine work, sub-assembly restoration: EVERYTHING.....1000 hours? 1500?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935984
02/25/11 01:45 PM
02/25/11 01:45 PM
Roswell, GA - near Atlanta
cloneguy Offline
super street
cloneguy  Offline
super street
They just did it in 6 hours on TV a few nights ago. That must be the new benchmark. (Although that was the losing team.)
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: Approx. hours for a partial rotieserre resto... [Re: DPelletier] #935985
02/25/11 04:38 PM
02/25/11 04:38 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
To me the bodywork/paint is fairly straight forward. The only caveat is the condition of the vehicle. The other stuff is way more subjective. Bolts for instance. If you by the correct bolts new from your favorite supply house and just replace upon assembly that saves time. If you are anal, as I am, and want every fastener that came off the car put back on it then the time really piles up. You have to inspect the old ones. Decide what is savable then clean them and send them out for plating. I prefer the latter even though I usually loose my ass on jobs like that. It is not just a correctness thing but a carma thing for me for a car to have as many born with parts put back on. The bolt example is just one of a bunch of the smaller things that really pile the hours/cash up in a hurry. Instruments, do you do them yourself and spend the hours or contract them out and save time but spend money. I would loosely say, if you go the anal route, and no sub contracting and all out of my or I should say one shop 2000 hours would not be out of the question. I know some White Post type guys that tell me a Duesenberg or high end MB type vehicle can get up to 5000+ hours.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Approx. hours for a partial rotieserre resto... [Re: sixpackbee] #935986
02/25/11 05:30 PM
02/25/11 05:30 PM
DPelletier Offline
DPelletier  Offline
Good point; sorta where I was going with the whole "scope" comment I made earlier. I know I'll have well over 1000 hours of time between my bodyshop, myself and a few friends that have helped me. What I wasn't sure of is how much time the machine shop spent, the sub assy's that Jules did for me, the instruments that were sent out, etc. etc.
I've spend untold amounts of time researching and trying to figure stuff out; that's where the pros have a HUGE advantage.
Re: Approx. hours for a partial rotieserre resto... [Re: formula_s] #935987
02/25/11 08:34 PM
02/25/11 08:34 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
Does 350 hours sound realistic? I read a site from a member here that said a typical top side resto will take about 300 hours.
Only if you let Maaco do it.
I lol'd at this.
A rotisserie will make that undercoating much easier. I had to do it from laying under the car and scraping.
Seems like heating the metal up from the backside with some form of heat and then scrape it off with a puddy knife/gasket scrapter/ect will make it easier. Whatever is left can be easily blasted off. Just my
Re: Approx. hours for a partial rotieserre resto... [Re: DPelletier] #935988
02/25/11 08:48 PM
02/25/11 08:48 PM
WI
RestoRick Offline
RestoRick  Offline
WI
One more factor not mentioned, when speaking of a turnkey type resto, is what model it is and how many options it has.
There's a world of difference in hours between something like a nice complete '65 Satellite non-air, manual everything strippo vs. a '71 Cuda convertible with a/c, PS, PB, power windows, 6way seat, etc, etc... Lots of extra parts to spruce up and get functioning correctly.
Also, extra or more complicated trim & brightwork adds more time.
Rick
Re: Approx. hours for a partial rotieserre resto... [Re: RestoRick] #935989
02/26/11 12:15 PM
02/26/11 12:15 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
FWIW; I am not a paint & body man but will tell you the above estimates of manhours is extremely hard to determine due to all of the unknown factors of hidden rust, previous repairs, etc.
I just had my '69 Road Runner done by a very reputable shop, wins Gold at the Mopar Nats quite often, and the final bill came out much higher than he or I were planning on. The car needed new quarters, a new hood, outer wheel wells replaced, new trunk pan & trunk extensions, work on the doors, fenders, etc. The car was structurally sound, no work to the roof, A or C pillars but it still took a lot more time than anticipated.
When the shell was delivered it already had the old quarters removed, the shell had been acid dipped and hand sanded and put in epoxy primer (I did that)and yet it took 678 manhours to complete the paint and body work. The 678 manhours did not include any re-assembly other than hanging the doors, fenders, hood and trunk. Now, this was not a partial restoration, it was full blown to replicate the way the car rolled off the assembly line and it is absolutely georgeous and correct, even the spot weld replications, drips in the underbody primer, overspray, etc.
I would think 400-500 hours would be pretty close depending on the extent of the work and the extent of hidden issues. I have had 2 paint/body men tell me to plan on 100 manhours for taping, painting, color sanding and buffing once it's ready to hit the paint booth so that leaves 300-400 hours for everything else, that's 10 weeks on the high side @ 40 hours per week. Just my
Re: Approx. hours for a partial rotieserre resto... [Re: Mopar Grandpa] #935990
02/26/11 02:34 PM
02/26/11 02:34 PM
cloneguy Offline
super street
cloneguy  Offline
super street
Grandpa, Your experience is why we do everything on a fixed bid. That way the customer never gets the sticker shock.
Your car would have been $18k flat plus parts and materials at our shop.
Re: Approx. hours for a partial rotieserre resto... [Re: cloneguy] #935991
02/26/11 03:19 PM
02/26/11 03:19 PM
Sebring, Florida
Sebring, Florida
NOW you tell me. Just kidding. Although the car was not a rust bucket there were quite a few places of hidden rust that had to be fixed and although I spent a lot more than I had budgeted I am extremely happy with the final product. When I die I'm not going to be able to take my checkbook with me cause I won't have a pocket to put it in.....I came into this world naked and I'm going out naked.
I have another car, '68 Barracuda Hemi car, that was done at another friend's shop and the bill was $30K and it wasn't an OE restoration and needed very few parts. How can you do them for $18K in labor?
Re: Approx. hours for a partial rotieserre resto... [Re: Mopar Grandpa] #935992
02/26/11 04:47 PM
02/26/11 04:47 PM
cloneguy Offline
super street
cloneguy  Offline
super street
Like you, when we die we won't be able to take anything with us. So, we figure there's no need to keep much extra on hand while we're here.
Seriously, we have average life styles in rural GA. Our overhead is next to nothing and we enjoy what we do.
We're also pretty good at what we do. We can't touch Alan when it comes to sub assembly restoration or reassembly but we fly when it comes to metal replacement, body and paint.
To clarify, I was comparing to the 678 hours you mentioned above. For $18k, we do the metal, body, paint, polish and body assembly and you do the final reassembly. Or we can do it but it's not included in the $18k price.
Re: Approx. hours for a partial rotieserre resto... [Re: cloneguy] #935993
02/26/11 05:32 PM
02/26/11 05:32 PM
anlauto Offline
anlauto  Offline
$26.55 per hour...
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935994
02/26/11 05:46 PM
02/26/11 05:46 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
$26.55 per hour...
That'd be a raise for me
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935995
02/26/11 09:30 PM
02/26/11 09:30 PM
cloneguy Offline
super street
cloneguy  Offline
super street
$26.55 per hour...
In fairness, we expect that we would be much faster than 678 hours to do the same job.
Page 2 of 3 1 2 3
