1972 cuda grill chrome #935385
02/23/11 10:45 AM
02/23/11 10:45 AM
Maryland
cudaboone Offline OP
Maryland
Help me cuda E BODY OWNERS: The two oval shaped chrome rings in the grill have spikes that slide into metal retainers that are clipped into the plastic of the grill. A couple of the push-in retainers are missing and a couple appear to be worn out. I have been all over the internet and cannot find these retaineres. ANYONE OUT THERE WHO CAN LEAD ME IN THE RIGHT DIRECTION?
Re: 1972 cuda grill chrome [Re: cudaboone] #935386
02/23/11 10:54 AM
02/23/11 10:54 AM
Maryland
mrob Offline
mrob  Offline
Maryland
I have a 73 Cuda so I know exactly what you're talking about. I couldn't find those retainers either so I ended up using push nuts to hold the trim in place. The pic below will give you an idea what I'm talking about. I found pushnuts at a local hardware store.
Hope this helps.
Re: 1972 cuda grill chrome [Re: cudaboone] #935387
02/24/11 06:35 AM
02/24/11 06:35 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I was missing a couple on my 74 Cuda. I found some clips that have a bigger round base (rather than the rectangular base for the Cuda), and are meant to push in like the Cuda grille clips, and then have a spike pushed through them. So they are basically like the Cuda clips, but designed for a round hole in the grille. I used a pliers to flatten them out so they fit nice and snug in my Cuda grille (without making any grille modifications), and the trim spikes are a perfect fit for them. They work great - I've had them holding the grille trim on since 2004 without a problem. I believe I got them at a NAPA that has a large section of clips and attachment hardware. I might still have the packaging around - if I can find it I'll post a manufacturer and part number for you.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 1972 cuda grill chrome [Re: Evil Monkey] #935388
02/24/11 09:21 AM
02/24/11 09:21 AM
Connecticut
biginchmotor Offline
Connecticut
Check out item # 190468551688 on E bay. Are these what you are looking for? John.
Re: 1972 cuda grill chrome [Re: biginchmotor] #935389
02/24/11 11:59 AM
02/24/11 11:59 AM
Maryland
Maryland
JOHN, YOU'RE THE MAN. THANKS. Just ordered them. Jerry.
