10" Brake Questions
#934690
02/22/11 12:08 AM
02/22/11 12:08 AM
Posts: 833 Marietta, GA
Joatha
Marietta, GA
I now need to piece together the brakes for my rear end. I have an 8.75 and I plan to run 10x2.5 brake shoes.
I don't have any of the brake hardware on this particular rear end (including no backing plates at this point). But, I do have an A-body 8.75 with the hardware as well as my A-body 7.25 (with 10" shoes) that is currently on the car (68 Barracuda). I know I need drums, shoes, backing plates, and the retaining springs/shafts (that hold the shoes in place). I expect the wheel cylinders will be required as well (but I'm not sure).
But, is there any compatibility between the rest of the hardware - springs, tensioner, etc? Can I reuse the rest from either of the 2 extra rear ends I have? It would make sense given that they are the same diameter.
1966 Barracuda
1968 Barracuda convertible
1930 Ford Model A (soon to be hemi equipped)
2006 Dodge 3500 4X4 CTD Quad Cab
Re: 10" Brake Questions
[Re: Joatha]
#934693
02/22/11 12:38 AM
02/22/11 12:38 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Since you don't have the backing plates, go to a swap meet or JY and buy some complete used setups for a few bucks then get new drums, springs, and shoes - easiest way.
Mine (11") came off a 74 van rear, you can find them on many years worth of vehicles.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#934694
02/22/11 12:53 AM
02/22/11 12:53 AM
Joatha
Marietta, GA
I assume I can get them off a C-body as well?
Makes me think I should consider 11x3 brakes as well.
1966 Barracuda
[Re: Joatha]
#934695
02/22/11 01:07 AM
02/22/11 01:07 AM
Posts: 70,126 Here
DirectSubjection
Here
I believe so yes - mine are 2.5" which are more than enough for my Duster (Wilwood disks front). I'm sure someone else can chime in with more knowledge.
#934696
02/22/11 01:14 AM
02/22/11 01:14 AM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) get a full setup from a JY I had a 12x3 from a 9 1/4 truck i run 11x2.5 on my a-body 8 3/4,they are off a 73 newport any B C D E F J R body will work 8 1/4 9 1/4 8 3/4 9 1/4 D-60/5 lug
#934697
02/22/11 03:04 PM
02/22/11 03:04 PM
Joatha
Marietta, GA
Thanks guys.
I have always been in to nothing but A-bodies and the ones I've had have been fairly stock. So, I've not been looking at interchanging. I've got AndyF's Viper disk set up on the front. So, I should be able to put some 11x2.5 or 11x3 brakes on the back and they'll work fairly well.
1966 Barracuda
[Re: Joatha]
#934698
02/22/11 07:04 PM
02/22/11 07:04 PM
Joatha
Marietta, GA
Does anyone know if the brake levers are the same across all 10" brakes? Or is it specific to the width?
1966 Barracuda
