Page 12 of 13 1 2 10 11 12 13
Re: New 5.7 hemi eagle head [Re: AlexP] #934517
10/31/14 06:40 PM
10/31/14 06:40 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: New 5.7 hemi eagle head [Re: MattW] #934518
10/31/14 07:35 PM
10/31/14 07:35 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
For a normally aspirated 392, what heads would you prefer for a street engine?
Original 5.7
6.1
Eagle
Apache
Also why would you pick the particular head?
Re: New 5.7 hemi eagle head [Re: hudsonhornet7x] #934519
10/31/14 07:39 PM
10/31/14 07:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
IMO its a toss up between the Eagles or 6.1. The 6.1's have hollow stem valves and a 73cc chamber, Eagles are solid stem and 65cc chamber so you need to plan accordingly.
Mopar to the bone!!!
Re: New 5.7 hemi eagle head [Re: hudsonhornet7x] #934520
11/01/14 04:26 AM
11/01/14 04:26 AM
MN
hemidup Offline
hemidup  Offline
MN
Original 5.7
6.1
Eagle
Apache
With a street motor that your not going to spin to the moon I'd go with worked over original 5.7 heads. The faster moving air from the 5.7 port will give you quicker throttle response and the low end torque needed for the street. My combo is a 392 with hand ported 5.7 heads and to get the most from them a 2.08" int valve and a 1.62" exh valve. I also D shaped and gasket matched the exh port opening.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: hemidup] #934521
11/01/14 10:47 AM
11/01/14 10:47 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Original 5.7
6.1
Eagle
Apache
Jerry you stoked your 6.1 crank to 3. Something correct? Using a Honda journal?
Plus I've heard in order to use a 2.08 valve you need to change the seat?
I like your setup and info. Thanks for sharing. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934522
11/01/14 01:34 PM
11/01/14 01:34 PM
MN
hemidup Offline
hemidup  Offline
MN
Original 5.7
6.1
Eagle
Apache
Your welcome. I offset ground the 6.1 crankshaft to a 3.80" stroke then used Eagle 1.88" Honda rod journal connecting rods, .927 pin with Ross pistons on top. With a 5.7 head you can get by using 2.05" int and 1.60" valves with the stock seats.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: MattW] #934523
11/01/14 05:56 PM
11/01/14 05:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok i have read this entire article. questions
1. bore-stroke of the 5.7
2. bore-stroke of the 6.1
3. bore-stroke of the 6.4
if going to bore-stroke the engine, would the 5.7 be the least expensive(it will be in the car)?
can the early heads on the 5.7 be ported to the size of the eagles?
I'm confused on the cams working with the older vs new head? machined differently? My project was to find an older Challenger then install the 6.1 engine,($5200.00) now it looks like the 5.7 would could be made up just as well, later upgrade to the hellcat supercharger. This is all new to me so steer me right please.
Re: New 5.7 hemi eagle head [Re: cudaman1969] #934524
11/01/14 06:41 PM
11/01/14 06:41 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
1 3.92 x3.58
2 4.055x 3.58
3 4.090x 3.72
4 bore and stroke will be cheapest depending on which block is cheapest.
yes
don't know about finding a new 6,1. good luck and jump on it if you find one.
Matt
Re: New 5.7 hemi eagle head [Re: hemidup] #934525
11/01/14 06:48 PM
11/01/14 06:48 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Original 5.7
6.1
Eagle
Apache
Thanks Jerry
I would love to pick you brain next year about putting a stroked 5.7 in my 03 Dakota.
Would like to know if my NGC will run the hemi with a tune?
Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934526
11/01/14 07:41 PM
11/01/14 07:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
1 3.92 x3.58
2 4.055x 3.58
3 4.090x 3.72
yes
Matt
"don't know about finding a new 6,1. good luck and jump on it if you find one"
can get a used one with 59,000 miles for $5200 out of a Charger with accessory's and boxes or one for $4,000 with 100,000 miles. maybe sell the 5.7
Re: New 5.7 hemi eagle head [Re: MattW] #934527
11/01/14 10:26 PM
11/01/14 10:26 PM
MN
hemidup Offline
hemidup  Offline
MN
Thanks Jerry
Matt
With HPTuners new support it shouldn't be a problem. I think the 03 4.7 Dak's are supported, but know for sure the 03 5.7 Ram's aren't.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: hemidup] #934528
11/01/14 10:35 PM
11/01/14 10:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'd love to put a 5.7 in my 08 Dakota as well. Need to get all I can out of this 4.7 first though, it only has about 76K on it. When does the 545rfe become worthless? I would want to go about 50hp shy of that lol.
Re: New 5.7 hemi eagle head [Re: 72Swinger] #934529
03/12/15 04:38 PM
03/12/15 04:38 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
67
Re: New 5.7 hemi eagle head [Re: MattW] #934530
03/12/15 05:18 PM
03/12/15 05:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
MattW, have you ever flowed a stock 6.1 head? Not Webers inflated numbers
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934531
03/12/15 05:41 PM
03/12/15 05:41 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Looking at 6.4 block and apache heads for a turbo motor in the 1,500+hp range, good idea???
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934532
03/12/15 06:58 PM
03/12/15 06:58 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
That is the only head I'm missing. And my quote was from the numbers on that site
I know BES did not favor the eagle head too much. they said it needed more work than the 6.1 to achieve the numbers for the first engine master challenge that the G3 won.
Matt
Re: New 5.7 hemi eagle head [Re: slammedR/T] #934533
03/12/15 07:04 PM
03/12/15 07:04 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
IMO yes.
All my info is from what others have stated and engine article i've found in mags.
As of right now I'm a closet G3 guy.
Soon to be a veteran
The 6.4 is a stronger block than the rest. IMO the Hellcat is a stock 6.4 that has been machined differently.
The only problem I see with the apache heads is the material they use for them. In high boost I believe the head will start to warp. At what level is the real question.
Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934534
03/12/15 07:09 PM
03/12/15 07:09 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Matt
Ill be flowing a set in about a hour and our numbers have been identical
Re: New 5.7 hemi eagle head [Re: slammedR/T] #934535
03/12/15 07:47 PM
03/12/15 07:47 PM
Canada
onig Offline
onig  Offline
Canada
Waiting to see those numbers.
69 Dart
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934536
03/12/15 10:07 PM
03/12/15 10:07 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Matt
