Re: New 5.7 hemi eagle head
[Re: hudsonhornet7x]
#934519
10/31/14 07:39 PM
10/31/14 07:39 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
IMO its a toss up between the Eagles or 6.1. The 6.1's have hollow stem valves and a 73cc chamber, Eagles are solid stem and 65cc chamber so you need to plan accordingly.
Mopar to the bone!!!
[Re: hemidup]
#934521
11/01/14 10:47 AM
11/01/14 10:47 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
For a normally aspirated 392, what heads would you prefer for a street engine?
Original 5.7
6.1
Eagle
Apache
Also why would you pick the particular head?
With a street motor that your not going to spin to the moon I'd go with worked over original 5.7 heads. The faster moving air from the 5.7 port will give you quicker throttle response and the low end torque needed for the street. My combo is a 392 with hand ported 5.7 heads and to get the most from them a 2.08" int valve and a 1.62" exh valve. I also D shaped and gasket matched the exh port opening.
Jerry you stoked your 6.1 crank to 3. Something correct? Using a Honda journal? Plus I've heard in order to use a 2.08 valve you need to change the seat? I like your setup and info. Thanks for sharing. Matt
[Re: cudaman1969]
#934524
11/01/14 06:41 PM
11/01/14 06:41 PM
MattW
Ontario Canada
Ok i have read this entire article. questions 1. bore-stroke of the 5.7 2. bore-stroke of the 6.1 3. bore-stroke of the 6.4 if going to bore-stroke the engine, would the 5.7 be the least expensive(it will be in the car)? can the early heads on the 5.7 be ported to the size of the eagles? I'm confused on the cams working with the older vs new head? machined differently? My project was to find an older Challenger then install the 6.1 engine,($5200.00) now it looks like the 5.7 would could be made up just as well, later upgrade to the hellcat supercharger. This is all new to me so steer me right please.
1 3.92 x3.58 2 4.055x 3.58 3 4.090x 3.72 4 bore and stroke will be cheapest depending on which block is cheapest. yes don't know about finding a new 6,1. good luck and jump on it if you find one. Matt
[Re: hemidup]
#934525
11/01/14 06:48 PM
11/01/14 06:48 PM
MattW
Ontario Canada
Original 5.7
6.1
Eagle
Apache
Your welcome. I offset ground the 6.1 crankshaft to a 3.80" stroke then used Eagle 1.88" Honda rod journal connecting rods, .927 pin with Ross pistons on top. With a 5.7 head you can get by using 2.05" int and 1.60" valves with the stock seats.
Thanks Jerry I would love to pick you brain next year about putting a stroked 5.7 in my 03 Dakota. Would like to know if my NGC will run the hemi with a tune? Matt
[Re: MattW]
#934526
11/01/14 07:41 PM
11/01/14 07:41 PM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
"don't know about finding a new 6,1. good luck and jump on it if you find one"
can get a used one with 59,000 miles for $5200 out of a Charger with accessory's and boxes or one for $4,000 with 100,000 miles. maybe sell the 5.7
[Re: hemidup]
#934528
11/01/14 10:35 PM
11/01/14 10:35 PM
72Swinger
Nebraska
I'd love to put a 5.7 in my 08 Dakota as well. Need to get all I can out of this 4.7 first though, it only has about 76K on it. When does the 545rfe become worthless? I would want to go about 50hp shy of that lol.
[Re: sixpackgut]
#934531
03/12/15 05:41 PM
03/12/15 05:41 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Looking at 6.4 block and apache heads for a turbo motor in the 1,500+hp range, good idea???
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: sixpackgut]
#934532
03/12/15 06:58 PM
03/12/15 06:58 PM
MattW
Ontario Canada
MattW, have you ever flowed a stock 6.1 head? Not Webers inflated numbers
That is the only head I'm missing. And my quote was from the numbers on that site
I know BES did not favor the eagle head too much. they said it needed more work than the 6.1 to achieve the numbers for the first engine master challenge that the G3 won. Matt
[Re: slammedR/T]
#934533
03/12/15 07:04 PM
03/12/15 07:04 PM
MattW
Ontario Canada
IMO yes. All my info is from what others have stated and engine article i've found in mags. As of right now I'm a closet G3 guy. Soon to be a veteran The 6.4 is a stronger block than the rest. IMO the Hellcat is a stock 6.4 that has been machined differently. The only problem I see with the apache heads is the material they use for them. In high boost I believe the head will start to warp. At what level is the real question. Matt
[Re: slammedR/T]
#934535
03/12/15 07:47 PM
03/12/15 07:47 PM
Posts: 361 Canada
onig
Canada
Waiting to see those numbers.
69 Dart
[Re: sixpackgut]
#934536
03/12/15 10:07 PM
03/12/15 10:07 PM
MattW
Ontario Canada
Ill be flowing a set in about a hour and our numbers have been identical
