Page 8 of 13 1 2 6 7 8 9 10 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934437
03/02/11 12:56 PM
03/02/11 12:56 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Who has the OEM Part # for the 6.1 crankshaft?
I don't want the Mopar Performance #. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934438
03/02/11 01:04 PM
03/02/11 01:04 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
05037458BD
is the latest and greatest one I think.
My opinion if you want a forged one, get one off ebay. They can be found dirt cheap!
http://cgi.ebay.com/ebaymotors/6-1-HEMI-...sQ5fAccessories
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: New 5.7 hemi eagle head [Re: wldtm] #934439
03/02/11 02:57 PM
03/02/11 02:57 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
05037458BD
Thank you sir.
Re: New 5.7 hemi eagle head [Re: MattW] #934440
03/12/11 11:54 AM
03/12/11 11:54 AM
ohio
all spooled up Offline
ohio
did any one flow these new heads thanks
Re: New 5.7 hemi eagle head [Re: all spooled up] #934441
03/12/11 06:42 PM
03/12/11 06:42 PM
ohio
ohio
Re: New 5.7 hemi eagle head [Re: all spooled up] #934442
04/01/11 09:21 PM
04/01/11 09:21 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Just got my set flowed 5.7 stock head
intake ............. exhaust
.100 72.2 ............ 56.6
.200 150.4 ............ 112.4
.300 217.3 ............ 148.9
.400 272.5 ............ 176.3
.500 299.2 ............ 183.6
.600 302 ............ 185
not bad for a STOCK HEAD. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934443
04/01/11 11:08 PM
04/01/11 11:08 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
not bad? are you kidding..thats phenominal..
272 @ .400" I lift
get them to CC the port runners while your at it.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: New 5.7 hemi eagle head [Re: cheapstreetdustr] #934444
04/01/11 11:40 PM
04/01/11 11:40 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
272 @ .400" I lift
cheapst
That with a 4" bore. Superflow 1020. I will try to CC the intake port tomorrow.
Re: New 5.7 hemi eagle head [Re: topbrent] #934445
04/02/11 12:43 AM
04/02/11 12:43 AM
MN
hemidup Offline
hemidup  Offline
MN
Few questions for the Gen III experts. Sorry if these are rudimentary and covered elsewhere...:
- How much lift can the stock rockers handle?
- How much spring can the stock rockers handle?
- At what point do the stock rockers become unsuitable, a liability, and/or unstable?
- Can you sufficiently cam the engine to use the higher lift flow that is available and still use the stock rockers?
- Can the stock rockers handle .600+ lift?
- Stock rocker's are safe to .585" lift.
- I'd be more concerned about spring rate. Manley or PSI are my favorite 2 of valve spring choices.
- Spun the stock rocker's up to 8400 rpm. The main concern is harmonic's and premature wear to the rockershaft's.
- ??? Probably not.
-No, unless you buy custom valve springs.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: cheapstreetdustr] #934446
04/02/11 01:05 AM
04/02/11 01:05 AM
MN
hemidup Offline
hemidup  Offline
MN
so $499 for the heads and $3000 for rockers
that dollar cost averages to $3499 for a 700+hp set of heads...?
whats the dilema?
cheapst
The $3000 Jessel rocker's + additional machining work? Don't bother unless you only want to spin the motor to 6500 rpm. The way the Jessel system works uses a hole drilled into the side of the lifter to pump them up from the lifter oil galley. Very old school and very lucky the lifters made it to 6500 rpm. Whereas with the stock top oil system, the oil is deadheaded at the lifter which darn near makes it a solid lifter which is good for 8000 rpm +.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: hemidup] #934447
04/02/11 01:18 AM
04/02/11 01:18 AM
houston texas
gremlinsteve Offline
houston texas
hi jerry!!!
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: New 5.7 hemi eagle head [Re: gremlinsteve] #934448
04/02/11 02:01 AM
04/02/11 02:01 AM
MN
hemidup Offline
hemidup  Offline
MN
hi jerry!!!
Hi Steve I'd really like to buy all those crankshafts.
Jerry Williams.
Re: New 5.7 hemi eagle head [Re: MattW] #934449
04/02/11 08:56 AM
04/02/11 08:56 AM
ohio
ohio
thanks
Re: New 5.7 hemi eagle head [Re: justinp61] #934450
04/02/11 10:08 PM
04/02/11 10:08 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Does anyone know of an actual build, 5.7, 6.1 stroker with actual dyno numbers? A list of parts? What will work together? Cams and valve train parts? These engins are capeable of a ton of power, but a guy could spend a lot of money and have a bunch os mismatched parts. I'd like to build one, a stroker, carbureted on pump gas that would make 650-700 hp. It may not be possible though .
It's possible, I saw a naturally aspirated 4100 lb. Charger streeter on slicks last week that has gone 10.70's in the 1/4.
Re: New 5.7 hemi eagle head [Re: LSP] #934451
04/02/11 10:32 PM
04/02/11 10:32 PM
houston texas
houston texas
dyno numbers...there are tons of the cars running those combinations and running very well.
steve
Re: New 5.7 hemi eagle head [Re: gremlinsteve] #934452
04/02/11 10:36 PM
04/02/11 10:36 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I forget what he told me on dyno #'s, I remember it was RWHP, Chris at ShopHemi can tell you all about it.
Re: New 5.7 hemi eagle head [Re: LSP] #934453
04/02/11 10:44 PM
04/02/11 10:44 PM
Smyrna, South Carolina
STEFF Online content
STEFF  Online Content
I've got Dyno Numbers!! My Gen 3 Hemi is still warm from being dyno'd out at Muscle Motors today. I'll post all the details tomorrow, in my own thread. I'm too pooped to do it right now.
Re: New 5.7 hemi eagle head [Re: LSP] #934454
04/02/11 10:50 PM
04/02/11 10:50 PM
houston texas
houston texas
for wich engine. i might know it already
steve
Re: New 5.7 hemi eagle head [Re: gremlinsteve] #934455
04/03/11 08:43 AM
04/03/11 08:43 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
steve
Was in a silver Charger.
Re: New 5.7 hemi eagle head [Re: MattW] #934456
04/04/11 01:41 AM
04/04/11 01:41 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
got this on the net." now for the useful stuff.
Cylinder heads. big changes here, new closed chamber heads have smaller chambers (duh) than previous engines , 66.3cc in fact vs 84.9cc. even smaller than the 6.1's with 73.0cc. bolting these on to a previous hemi without modification would result in nearly a 12:1 compression ratio.
Are there pistons available to get a lower compression ratio than 12:1 using these heads on an earlier engine?I assume the stock later piston would work,not sure what CR is on late hemis though.
RT
