Page 2 of 13 1 2 3 4 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934317
02/22/11 12:50 PM
02/22/11 12:50 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Much as I like the Gen 3, don't forget the discontinued
59 degree W9 also flowed 300 out of the box and had potential above and beyond that.
But comparing an aftermarket race head to a dirt cheap OE production head ain't exactly fair
As far as the block taking it goes, there is a reason MP built the 392 at std bore, and it was not out of laziness. Don't bore it. It will surprise you.
Rich H.
Esse Quam Videri
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934318
02/22/11 12:52 PM
02/22/11 12:52 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Pictures are coming I have to figure out how to resize them.
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934319
02/22/11 12:55 PM
02/22/11 12:55 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
They need to start racing these things in roundy round cars then I think people would start buying. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934320
02/22/11 12:58 PM
02/22/11 12:58 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
53021608DE 53021609DE left and right head.
$704 out the door at my local dealer.
Re: New 5.7 hemi eagle head [Re: MattW] #934321
02/22/11 01:25 PM
02/22/11 01:25 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Penske has done their research on them years ago and asked permission from NASCAR to use it and they said No. gotta love that
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934322
02/22/11 02:07 PM
02/22/11 02:07 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Penske has done their research on them years ago and asked permission from NASCAR to use it and they said No. gotta love that [/quote
Never mind the big leagues go with grass root get enough demand and .......
So if the new srt 8 is using the 5.7 Me thinks the 6.1 is on the chopping block.
Hey ZIPPY PLEASEEEEEE ask them to turn the 6.1 into a siameses bore block before they they scrap it. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934323
02/22/11 03:03 PM
02/22/11 03:03 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I just called my parts guy.
The price i got was pretty damn impressive.
But he says there is note that the heads have
no valve train on them, says they are core heads.
So who has actaully seen these heads and what comes on them?
Re: New 5.7 hemi eagle head [Re: HEMIDARTS] #934324
02/22/11 03:14 PM
02/22/11 03:14 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I have them in front of me. Mine came assembled and with spark plugs.
No rocker arms or shafts.
Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934325
02/22/11 03:16 PM
02/22/11 03:16 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Ok who knows how to resize a picture on a MacBook
Re: New 5.7 hemi eagle head [Re: MattW] #934326
02/22/11 03:19 PM
02/22/11 03:19 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
Matt
This is correct, my son has a set we bolted them on untouched & they work great
Re: New 5.7 hemi eagle head [Re: mopardad] #934327
02/22/11 03:28 PM
02/22/11 03:28 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I was surprised when I opened the box. Go to be close to $100 in plugs.
Re: New 5.7 hemi eagle head [Re: MattW] #934328
02/22/11 03:31 PM
02/22/11 03:31 PM
Toronto
mshred Offline
mshred  Offline
Toronto
if you dont mind me asking, how much did you pay for them and what local dealer did you get them from?
Re: New 5.7 hemi eagle head [Re: MattW] #934329
02/22/11 03:52 PM
02/22/11 03:52 PM
S.E. Michigan
S.E. Michigan
Already did, about a year ago or therabouts.
Response was aluminum, aluminum, and aluminum.
That was the end of that
Rich H.
Esse Quam Videri
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934330
02/22/11 04:03 PM
02/22/11 04:03 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
googled the pt#'s and came up with some tampa dealers. $222 each
http://checkanumber.com/advsearch.php?start=290200
Re: New 5.7 hemi eagle head [Re: mshred] #934331
02/22/11 04:24 PM
02/22/11 04:24 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
The best over here was 359.00 Canadian. Look at Dodgeparts.com it will give you a ballpark figure. You may get them cheaper there but remember, when you buy from a dealer close to you, you save delivery. Matt
Re: New 5.7 hemi eagle head [Re: ZIPPY] #934332
02/22/11 04:35 PM
02/22/11 04:35 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Yeah I figure they are catering to people with money.
I just read that the 392 is only going to be 1492 units, so maybe the 6.1 isn't dead.
Re: New 5.7 hemi eagle head [Re: MattW] #934333
02/22/11 04:36 PM
02/22/11 04:36 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Matt
Ok so you just use the stock valve train off of another set of heads.
Thanks for your help!
Re: New 5.7 hemi eagle head [Re: HEMIDARTS] #934334
02/22/11 04:41 PM
02/22/11 04:41 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Matt
Or afterrmarket. Harland Sharp , Jesel, and Rocker ARM Specialist is rumored to be coming out with a set. I am sure TD has something in the works.
Re: New 5.7 hemi eagle head [Re: MattW] #934335
02/22/11 05:19 PM
02/22/11 05:19 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i just paid $494. had to put them on a card. so it will probably turn into $800
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934336
02/22/11 05:34 PM
02/22/11 05:34 PM
dearborn heights michigan usa
brianw Offline
brianw  Offline
if you swap heads you will have a oil leak . the drain backs are in different positions from one side to the other . if you swap manifolds you should be able to drill and tap for the extra bolt holes
