Re: what do you use to block off heater hose fitting on w.p
[Re: dOoC]
#933931
02/21/11 05:39 PM
02/21/11 05:39 PM
Posts: 1,012 indiana
mcmopars
indiana
There is a steel plug you can use OR a rubber cap.
i didnt know if a rubber cap would hold up under pressure.tell me about steel plug?
[Re: mcmopars]
#933932
02/21/11 06:09 PM
02/21/11 06:09 PM
Posts: 15,487 Florida
scratchnfotraction
heater block off caps from napa work just fine and are cheap just tap it with a npt pipe thred and use a pipe plug either works just fine,I use the rubber caps on all of mine,but i do change them about every 3-4 yrs i have only had one fail on a wot pass but it was close to 12 yrs old,I change them out every so often now
[Re: mcmopars]
#933934
02/21/11 06:39 PM
02/21/11 06:39 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
i dont use the heater core.the fitting on the intake isnt a problem as it is threaded and a bolt will go in there.
No, this will be a problem , the intake is tapped to NATIONAL PIPE THREAD, NPT , so you aren't going to put a traditional BOLT in it .
[Re: AndyF]
#933938
02/21/11 06:54 PM
02/21/11 06:54 PM
mcmopars
indiana
I assume this is a SB? You can buy water pumps with a threaded fitting rather than the cast nipple. Then you use a pipe plug and that gives you a very secure block off.
If you stay with the water pump housing with the cast in nipple then I'd recommend a bypass hose rather than rubber cap. Just put the fitting back into the intake manifold and run a short loop of heater hose.
There are lots of ways to do this, just depends on how much "hillbilly" blood you have in you!
i got the loop now but it looks kinda tacky
[Re: mcmopars]
#933939
02/21/11 07:36 PM
02/21/11 07:36 PM
Posts: 3,344 Central TX
roe
Central TX
i just looped mine with a short piece of hose. works for me
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: AndyF]
#933940
02/21/11 07:57 PM
02/21/11 07:57 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
...just depends on how much "hillbilly" blood you have in you!
Ouch, and I Bought the Book.
I used this method till I upgraded to an aluminum pump and I up'd for the brass plugs. If unsure about size take the pump with you to the Napa etc.
[Re: GwaiiEagle]
#933941
02/21/11 09:22 PM
02/21/11 09:22 PM
Posts: 31,050 Oregon
AndyF
One thing I've learned on Moparts over the years is that some people care about how stuff looks and others don't. I used to wonder about some of the advice that got handed out until I finally realized that some people are perfectly happy using a screwdriver to open the trunk. So these days I try to give a range of answers and let people pick the one that fits their budget and/or their ability.
[Re: DirectSubjection]
#933943
02/21/11 10:29 PM
02/21/11 10:29 PM
RapidRobert
The looped hose works but looks bad, the caps/clamps look less bad & work & last along time. Best is see if the nipples will come out easily w a pipe wrench or vice grips & if not heat the base threads w a small tip on the hot wrench let some candle wax (bees wax is reportedly the best) wick in then take em out & add a common hardware store pipe plug (they are NPT just like the nipples you are taking out, no drilling/retapping needed) either an internal hex or the external square (what you see in the above pic) w white teflon pipe dope or tape on the threads (w tape wrap it CW looking at the threaded end of the plug)
[Re: AndyF]
#933946
02/21/11 11:22 PM
02/21/11 11:22 PM
RapidRobert
Yeah Andy I missed that, I saw the pic & went w that
[Re: RapidRobert]
#933947
02/22/11 08:20 AM
02/22/11 08:20 AM
mcmopars
indiana
