what do you use to block off heater hose fitting on w.p #933928
02/21/11 05:17 PM
02/21/11 05:17 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i dont use the heater core.the fitting on the intake isnt a problem as it is threaded and a bolt will go in there.what will fit on the water pump and look good? it is a nipple,im not sure if a cap with a hose clamp will work,it wont look real clean either.what have you used that looks good?
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933929
02/21/11 05:22 PM
02/21/11 05:22 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Not very useful since I don't remember the size. But I found a tap that required just a little larger hole than the I.D of the nipple. Drilled and tapped it for a plug, never had any issues with it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933930
02/21/11 05:33 PM
02/21/11 05:33 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
There is a steel plug you can use OR a rubber cap.
Re: what do you use to block off heater hose fitting on w.p [Re: dOc …] #933931
02/21/11 05:39 PM
02/21/11 05:39 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i didnt know if a rubber cap would hold up under pressure.tell me about steel plug?
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933932
02/21/11 06:09 PM
02/21/11 06:09 PM
scratchnfotraction Offline
heater block off caps from napa work just fine and are cheap
just tap it with a npt pipe thred and use a pipe plug
either works just fine,I use the rubber caps on all of mine,but i do change them about every 3-4 yrs
i have only had one fail on a wot pass but it was close to 12 yrs old,I change them out every so often now
Re: what do you use to block off heater hose fitting on w.p [Re: scratchnfotraction] #933933
02/21/11 06:16 PM
02/21/11 06:16 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ok thanks,ill try the rubber caps and keep an eye on them
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933934
02/21/11 06:39 PM
02/21/11 06:39 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
No, this will be a problem , the intake is tapped to NATIONAL PIPE THREAD, NPT , so you aren't going to put a traditional BOLT in it .
Re: what do you use to block off heater hose fitting on w.p [Re: JohnRR] #933935
02/21/11 06:45 PM
02/21/11 06:45 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you'll destroy the threads on the housing! it's better to visit the plumbing section of Home Depot.
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933936
02/21/11 06:46 PM
02/21/11 06:46 PM
AndyF Offline
AndyF  Offline
I assume this is a SB? You can buy water pumps with a threaded fitting rather than the cast nipple. Then you use a pipe plug and that gives you a very secure block off.
If you stay with the water pump housing with the cast in nipple then I'd recommend a bypass hose rather than rubber cap. Just put the fitting back into the intake manifold and run a short loop of heater hose.
There are lots of ways to do this, just depends on how much "hillbilly" blood you have in you!
Re: what do you use to block off heater hose fitting on w.p [Re: JohnRR] #933937
02/21/11 06:51 PM
02/21/11 06:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
remove niples and fit:
or
Re: what do you use to block off heater hose fitting on w.p [Re: AndyF] #933938
02/21/11 06:54 PM
02/21/11 06:54 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i got the loop now but it looks kinda tacky
Re: what do you use to block off heater hose fitting on w.p [Re: mcmopars] #933939
02/21/11 07:36 PM
02/21/11 07:36 PM
Central TX
roe Offline
roe  Offline
Central TX
i just looped mine with a short piece of hose. works for me
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: what do you use to block off heater hose fitting on w.p [Re: AndyF] #933940
02/21/11 07:57 PM
02/21/11 07:57 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
...just depends on how much "hillbilly" blood you have in you!
Ouch, and I Bought the Book.
I used this method till I upgraded to an aluminum pump and I up'd for the brass plugs. If unsure about size take the pump with you to the Napa etc.
Re: what do you use to block off heater hose fitting on w.p [Re: GwaiiEagle] #933941
02/21/11 09:22 PM
02/21/11 09:22 PM
AndyF Offline
AndyF  Offline
One thing I've learned on Moparts over the years is that some people care about how stuff looks and others don't. I used to wonder about some of the advice that got handed out until I finally realized that some people are perfectly happy using a screwdriver to open the trunk. So these days I try to give a range of answers and let people pick the one that fits their budget and/or their ability.
Re: what do you use to block off heater hose fitting on w.p [Re: AndyF] #933942
02/21/11 09:33 PM
02/21/11 09:33 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I've been using the rubber cap/clamp deal, but just the other day my buddy and I wear thinking of tapping for a plug. I have taps for up to 1/2" NPT.
Ride eternal, shiny and chrome
Re: what do you use to block off heater hose fitting on w.p [Re: DirectSubjection] #933943
02/21/11 10:29 PM
02/21/11 10:29 PM
The looped hose works but looks bad, the caps/clamps look less bad & work & last along time. Best is see if the nipples will come out easily w a pipe wrench or vice grips & if not heat the base threads w a small tip on the hot wrench let some candle wax (bees wax is reportedly the best) wick in then take em out & add a common hardware store pipe plug (they are NPT just like the nipples you are taking out, no drilling/retapping needed) either an internal hex or the external square (what you see in the above pic) w white teflon pipe dope or tape on the threads (w tape wrap it CW looking at the threaded end of the plug)
Re: what do you use to block off heater hose fitting on w.p [Re: RapidRobert] #933944
02/21/11 11:15 PM
02/21/11 11:15 PM
UK
602heavy Offline
602heavy  Offline
UK
Might be missing something here cos i can't remember .................blocking those heater hose outlets won't allow any water to flow through block & heads until thermostat opens , this is the reason for the 'loop' , fine to plug em off if you don't run a thermostat (or drill stat)........block temps will be a lot higher than temps @ water pump neck , with no water flowing through block & heads heads 'hot spots' will cause block scaling & worse still can crack when thermostat opens.
Re: what do you use to block off heater hose fitting on w.p [Re: RapidRobert] #933945
02/21/11 11:17 PM
02/21/11 11:17 PM
AndyF Offline
AndyF  Offline
On a small block the nipple doesn't always come out. Most small block water pumps have a cast nipple. Big blocks are screw in. I believe the OP has a small block although it doesn't appear that he ever stated that.
Re: what do you use to block off heater hose fitting on w.p [Re: AndyF] #933946
02/21/11 11:22 PM
02/21/11 11:22 PM
Yeah Andy I missed that, I saw the pic & went w that
Re: what do you use to block off heater hose fitting on w.p [Re: RapidRobert] #933947
02/22/11 08:20 AM
02/22/11 08:20 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
yea it is a small block
