512 "Street Motor" Dyno Results #933532
02/20/11 10:11 PM
02/20/11 10:11 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I built this low stressed motor for the street to run on pump gas and to be installed in my 67 Coronet. So be easy on me fellas, this is not a race motor; I just wanted a good 500 hp motor. It is a World cast iron block, 512 with 4.375" bore and 4.250" stroke, Diamond dish pistons with Indy EZ heads (75cc) ending up with a 10.2:1 cr. Scott Brown hyd cam int: 245@.050" ex: [Email]254@.050" with .565" lift. Johnsosn anti- pump up lifters and Indy 1.5:1 roller rockers. Indy dual plane topped off with a 850 Mighty Demon carb. Firecore coil and mechanical dist. (last pull was @ 36 degrees total)
I want to thank Dave's Performance (QUICKD100) for helping me out and operating the dyno and doing a lot of adjustments/troubleshooting for me the last couple of days also to Maximus_Wedges and ANDYF.
Saturday we installed the motor on the dyno and after having Some timing, fuel and Demon carb issues we finally fired it up and broke in the cam. This morning (Sunday) we pulled the plugs, changed and inspected the oil filter and inspected the rockers. After a couple of great pulls with an 850 Holley, Dave went back and setup the Demon with baseline air bleeds and richened up the primary side.
We ended up with 600 ft lbs of torque@3200 rpm and peaked at 621 ft lbs@3666 rpm and stayed around 600 all the way to 4750 rpm and not dropping off much all the way to 5500 rpm(535 ft lbs). HP numbers were 562hp@5551 rpm. Needless to say, I was very pleased with the numbers. I will try and cut and paste the numbers tomorrow. This has got one flat torque curve and should be fun in my Coronet.
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933533
02/20/11 10:15 PM
02/20/11 10:15 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
nice little tq monster,should be plenty for sat night cruising
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933534
02/20/11 10:16 PM
02/20/11 10:16 PM
Delray beach, Florida
P
Performance Only Offline
P
that's a great street combo. you'll have a lot of fun with it. we've done dozens of similar combos like that for street use. i hope the rest of the drivetrain is up to the challenge of that torque.
should also be very easy maintenance.
machine shop owner and engine builder
Re: 512 "Street Motor" Dyno Results [Re: Performance Only] #933535
02/20/11 10:23 PM
02/20/11 10:23 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Here are a couple of dyno sheet numbers
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933536
02/20/11 10:26 PM
02/20/11 10:26 PM
tboomer Online work
tboomer  Online Work
Great street moder!! Ol Mayor Dave is doing a good job on that dyno!!
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933537
02/20/11 10:27 PM
02/20/11 10:27 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933538
02/20/11 10:29 PM
02/20/11 10:29 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
NIIICE job, buddy!
You'll have a lot of fun with all that torque.
Excellent choice of components, everything works together really well.
You probably have another 20+ up top with just a bigger carb, especially with that awesome indy Dual plane. My old (and very similar) 508 loved a pro-systems 1000hp.
WIZE
In Car:
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933539
02/20/11 10:44 PM
02/20/11 10:44 PM
P
P
does the dyno have any other info like bsfc, scfm, etc? would love to see it if it does. (most do)
Re: 512 "Street Motor" Dyno Results [Re: Streetwize] #933540
02/20/11 11:20 PM
02/20/11 11:20 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
NIIICE job, buddy!
The motor only was using [Email]756cfm@5900rpm.[/Email] I wasn't real happy with the BG carb, it was supposed to be tuned for this combo when Larry recieved it. The air bleeds were WAYYYY off right from BG. It was dead lean, I replaced the bleeds and installed sizes listed on their website. The carb still didn't want to run. I ended up completely disassembling and cleaning it. The primary block was screwed up from BG, looked like someone had missed the center drilling a hole and decided to try again. They ended up with a figure 8 on one side. We screwed around fighting carburation for a day. I'm quite sure we could have found some more power with more time on the dyno. We met and exceded Larry's goals for the motor though. Larry did a great job designing this little street terror.
We did all the pulls on 110race gas as we initially got a bad batch of 91. Maximus Wedges, Kevin, was kind enough to run home 30 miles and bring some 110 race gas back to save the day.
With the torque the motor makes Larry will be buying alot of rear tires this summer. Dave
Re: 512 "Street Motor" Dyno Results [Re: quickd100] #933541
02/20/11 11:28 PM
02/20/11 11:28 PM
tboomer Online work
tboomer  Online Work
Dave...I would have sent my new Victor up for Kevin to test against his M-1...That would have been cool!!
Re: 512 "Street Motor" Dyno Results [Re: tboomer] #933542
02/20/11 11:50 PM
02/20/11 11:50 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Ted; If we'd had it there we'd have certainly tested it. I wish I was financially independent, all I'd do is help friends with their motors and projects. (Along with mine too) Work keeps rearing it's ugly head though so most times my time is limited. Dave
Re: 512 "Street Motor" Dyno Results [Re: quickd100] #933543
02/20/11 11:54 PM
02/20/11 11:54 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: 512 "Street Motor" Dyno Results [Re: quickd100] #933544
02/21/11 12:00 AM
02/21/11 12:00 AM
tboomer Online work
tboomer  Online Work
Dave....I would have sent it up on my dime...No problem!! I just think it is cool what you are doing!!
Re: 512 "Street Motor" Dyno Results [Re: tboomer] #933545
02/21/11 11:23 AM
02/21/11 11:23 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Dave sure enjoys what he does and he does not give up when faced with a problem; he likes little challenges. Without the dyno and his expertise I would've probably ruined the motor if I'd done the break in in the car. Lesson learned; carb was supposed to be ready to go (don't assume anything, check it yourself) Again, thanks a bunch Mayor Dave!!!
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933546
02/21/11 11:32 AM
02/21/11 11:32 AM
NC
440Jim Offline
440Jim  Offline
NC
621 ft-lbs at 3666 rpm
562 hp at 5551 rpm
That is a low rpm torque monster. Very street friendly.
Ofcourse I would have put more cam in it, the 512 CID would still have more torque than the tires will handle on the street.
Enjoy!
Re: 512 "Street Motor" Dyno Results [Re: 440Jim] #933547
02/21/11 11:37 AM
02/21/11 11:37 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks 440Jim, I am going to run it a while and maybe upgrade the cam later. I know from past engines I've built these big inch mopars will take a lot of cam and still idle well.
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933548
02/21/11 12:36 PM
02/21/11 12:36 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Excellent Post... Just what I wanted to read. I will be attemting to do almost the same engine here in the future for my 70 Coronet.
World Iron Block 4.395 Bore, Callies 4.250 Stroke Crank. Pump Gas is a must. Still undecided on the Heads and Cam. Hydraulic Roller or Small Solid since I have bushed lifter bores.
What oiling system are you running on this? Transmission upgrades? Rear end? and if you could change anything (or things) what would it be? AndyF and Scotty Brown are both huge helps with these combos.
Thanks for the post.
Re: 512 "Street Motor" Dyno Results [Re: Bubba] #933549
02/21/11 02:02 PM
02/21/11 02:02 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I am running a 3/8" pickup with a milodon 6 qt hemi pan. The world 1/2" adapter would not clear the rods as I am using Mopar size rod throws. I would've preferred to use the Chevy size throws but K-1 were out of them, then I could've run a bigger pickup. But this engine wont see much more than 5500 rpm. I have an external pickup setup in the box but with the stock motor mounts it would be a chore to route the line around the mounts and the power steering box. I also am going to change the dist to an MSD unit as there is no adjustment, short of disassembling the firecore dist. The advance is only 14 degrees and to get the 36 total I had to set it at 22 degrees initial and it wanted to kick back a litte on startup. I was going go with a vacuum advance dist but they would not clear the Indy EZ heads, so you are stuck with a mechanical or take the chance and mill off some of the head for clearance. I don't have a transmission yet but put a 3.55:1 8 3/4 rearend in the Coronet.
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933550
02/21/11 02:06 PM
02/21/11 02:06 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Excellent... Thank you.
Re: 512 "Street Motor" Dyno Results [Re: Hemi_Ram] #933551
02/21/11 02:08 PM
02/21/11 02:08 PM
organ
maximum entropy Offline
organ
you're gonna need a bigger tire...
