Proper way to check a coil #933105
02/20/11 03:23 PM
02/20/11 03:23 PM
Texas
70Runnerdude Offline OP
Texas
How do you check a coil to see if it is good ?
Thanks!
Re: Proper way to check a coil [Re: 70Runnerdude] #933106
02/20/11 03:42 PM
02/20/11 03:42 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
hold the coil wire in your hand and crank the engine. if your hair stands straight up, it's good. if it only lifts a little, replace it! sorry, i couldn't resist
Re: Proper way to check a coil [Re: mikemee1331] #933107
02/20/11 04:10 PM
02/20/11 04:10 PM
Texas
Texas
Some people just have to be a JERK.
Re: Proper way to check a coil [Re: 70Runnerdude] #933108
02/20/11 04:27 PM
02/20/11 04:27 PM
touch your ohmeter leads to the 2 pri terminals (on the low scale) & may get .9 ohms for the primary circuit. Then keep one lead on one of the (either one) pri terminals & touch the other one to the sec tower on X1000 scale for secondary resistance. This'll show that both circuits have or do not have continuity but a coil can (bench) test OK here and act up when hot but if you have a suspect coil this'll get you started
Re: Proper way to check a coil [Re: 70Runnerdude] #933109
02/20/11 05:06 PM
02/20/11 05:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sorry, bad case of cabin fever!
Re: Proper way to check a coil [Re: mikemee1331] #933110
02/20/11 08:39 PM
02/20/11 08:39 PM
places
79powerwagon Offline
places
Don't feel bad. I almost said "Touch it to your tongue", but I refrained from such nonsense!
Re: Proper way to check a coil [Re: 79powerwagon] #933111
02/20/11 09:40 PM
02/20/11 09:40 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Actually, Rapids method does not guarantee that "it is good." You cannot really check a coil with an ohmeter. They can be arcing over at high speed, over-heating and shorting internally, etc.
Best way to check a coil is simply have a known good spare. "New" does not mean good.
Re: Proper way to check a coil [Re: 70Runnerdude] #933112
02/20/11 09:57 PM
02/20/11 09:57 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Please tell me you didn't expect at least one response like that!! I'm bummed I got treed or I would have posted it!! Lighten up!!
Re: Proper way to check a coil [Re: 79powerwagon] #933113
02/20/11 11:31 PM
02/20/11 11:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Wrong technique!,...don't you know that only works on 9 volt batteries
Re: Proper way to check a coil [Re: DAYCLONA] #933114
02/21/11 12:25 AM
02/21/11 12:25 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah the coil test requires the you have someone else crank the engine while you pee on the coil wire.. Yeah I'm a jerk too......
Re: Proper way to check a coil [Re: 1_WILD_RT] #933115
02/21/11 12:45 AM
02/21/11 12:45 AM
A guy just died from that on "A 1,000 ways to die" but it was an electric fence
Re: Proper way to check a coil [Re: RapidRobert] #933116
02/21/11 12:49 AM
02/21/11 12:49 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
He didn't do it right... Someone should try it again...It sure as h3ll won't be me...
Re: Proper way to check a coil [Re: 1_WILD_RT] #933117
02/21/11 05:28 PM
02/21/11 05:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i was going to suggest the 'pee test' but i thought the moderator would zap it! good to see a sense of humor here. i guess mine was just ill-timed!
Re: Proper way to check a coil [Re: mikemee1331] #933118
02/21/11 06:31 PM
02/21/11 06:31 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
mikemee in Alabama that was funny!!!!
