Re: Proper way to check a coil
[Re: 70Runnerdude]
#933108
02/20/11 04:27 PM
02/20/11 04:27 PM
RapidRobert
touch your ohmeter leads to the 2 pri terminals (on the low scale) & may get .9 ohms for the primary circuit. Then keep one lead on one of the (either one) pri terminals & touch the other one to the sec tower on X1000 scale for secondary resistance. This'll show that both circuits have or do not have continuity but a coil can (bench) test OK here and act up when hot but if you have a suspect coil this'll get you started
[Re: mikemee1331]
#933110
02/20/11 08:39 PM
02/20/11 08:39 PM
Posts: 27,728 places
79powerwagon
places
Some people just have to be a JERK.
sorry, bad case of cabin fever!
Don't feel bad. I almost said "Touch it to your tongue", but I refrained from such nonsense!
[Re: 70Runnerdude]
#933112
02/20/11 09:57 PM
02/20/11 09:57 PM
Posts: 4,950 WI
Dcuda69
WI
Please tell me you didn't expect at least one response like that!! I'm bummed I got treed or I would have posted it!! Lighten up!!
[Re: 79powerwagon]
#933113
02/20/11 11:31 PM
02/20/11 11:31 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Wrong technique!,...don't you know that only works on 9 volt batteries
