implement paint, you ever use it? #93301
07/23/08 12:36 AM
07/23/08 12:36 AM
Galveston,IN
jackel440 Offline OP
Galveston,IN
I would like to repaint my daily driver beater truck.Its a 92' w150.I want to pain it up like a 79' Macho power wagon.The silver paint is peeling off every where so I thought I could paint it with implement paint to save some bucks ,and have a cool lookn truck.
Does anyone have any experiance using it?what to look out for or expect?I painted my 72 charger with a single stage paint 4 or 5 yrs ago.I don't want to spend that much on paint.Any info?
Thanks guys
Re: implement paint, you ever use it? [Re: jackel440] #93302
07/23/08 01:00 AM
07/23/08 01:00 AM
made the mistake of using it on the bed of my rolloff flatbed, faded real bad now i need to sandblast & paint
Re: implement paint, you ever use it? [Re: jackel440] #93303
07/23/08 02:19 AM
07/23/08 02:19 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
https://board.moparts.org/ubbthreads/show...e=7#Post3493382
Might be something in here that's useful...good luck.
Re: implement paint, you ever use it? [Re: jackel440] #93304
07/23/08 07:26 AM
07/23/08 07:26 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Whatever brand you use, make sure you use a good quality roller !!!
Re: implement paint, you ever use it? [Re: Stanton] #93305
07/23/08 08:10 AM
07/23/08 08:10 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
try using boat topside paint, like Interlux's brightside. it's about $35/qt at west marine.
2017 Grand Cherokee Overland
Re: implement paint, you ever use it? [Re: patrick] #93306
07/23/08 09:21 AM
07/23/08 09:21 AM
Galveston,IN
Galveston,IN
I hadn't planned on doing the roller method i was just going to squirt it on the truck.
So there might be an issue of the paint fading due to exposure from the sun?That would suck.
Re: implement paint, you ever use it? [Re: jackel440] #93307
07/23/08 09:56 AM
07/23/08 09:56 AM
scratchnfotraction Offline
I have sprayed some tractor paint from tractor supply
painted some mud trucks with it,did the
john deere yellow,green 2 trucks
kubota orange
gloss black
shade tree but looks good for a beater and what we are doing
thats prob the same paint ya talkin bout,I say go for it,ours have turned out ok and are holdin up
gonna try the massy fergison red next
gonna paint the frame and 2 1/4 ton axles with the 4 link on this one and the truck will be green
kinda populary for us off road guys around here in FL
Re: implement paint, you ever use it? [Re: jackel440] #93308
07/23/08 09:57 AM
07/23/08 09:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
PPG has a cheap acrylic enamel single stage that should work very nicely ...
Re: implement paint, you ever use it? [Re: JohnRR] #93309
07/23/08 10:56 AM
07/23/08 10:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
you can thin and spray the topside paint, too...it's basically a non-catylized single stage uerethane....
Re: implement paint, you ever use it? [Re: patrick] #93310
07/23/08 11:57 AM
07/23/08 11:57 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
As much as I hate to admit it, I've heard good things from people who have used John Deere paint.
http://www.crankshaftcoalition.com/wiki/John_Deere_Blitz_Black_paint
Just do a search for John Deere Blitz Black.
http://www.rodandcustommagazine.com/featuredvehicles/0710rc_1927_ford_roadster_lowboy/index.html
Re: implement paint, you ever use it? [Re: mopowers] #93311
07/23/08 03:09 PM
07/23/08 03:09 PM
Galveston,IN
Galveston,IN
I looked at the paint in the rural king store we have here(just like a TSC) and it also has a hardner you can mix with it.I have a friend who shot his 1000 gal LP tank with some off white color.it looked ok ,but he didn't do much prep on it.
I wondered if i can wet sand it and polish it. I might have to jusr try it and see what happens.
Re: implement paint, you ever use it? [Re: scratchnfotraction] #93312
07/23/08 03:10 PM
07/23/08 03:10 PM
Galveston,IN
Galveston,IN
kubota orange
gloss black
you got any pics of those trucks? like to see how they turned out.
Re: implement paint, you ever use it? [Re: JohnRR] #93313
07/23/08 03:12 PM
07/23/08 03:12 PM
John is right.. ppg low line paints are called the
"Omni" line. Available in acrylic enamel, single stage urethane, and Base/clear.
They work very well for a fraction of the cost of high line paints.
Check them out!!
Re: implement paint, you ever use it? #93314
07/23/08 08:17 PM
07/23/08 08:17 PM
Nashport, OH
chargers777 Offline
chargers777  Offline
Nashport, OH
TSC sells valspar paint.They have an automotive grade restoration series paint.Valspar owns House of kolor and is very good paint.if you use hardner it can be wet sanded and buffed.I got some for 1 cent once because the can was damaged and they couldnt give it away.I sprayed a 73 satellite with it and it worked great.This was black and it looked really good.I also sprayed a 1970 charger rt/se with valspar enamel (automotive grade) 6 years ago and it still looks great.The guy who owns it just sent me a recent picture.It is easy to run tho and does take awhile to dry.
Re: implement paint, you ever use it? [Re: jackel440] #93315
07/23/08 09:36 PM
07/23/08 09:36 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I used the cheap tractor paint on my flat bed car haulin trailer. I thinned it and sprayed it on. I looked great but faded / oxidized very fast.
