1970 B - Body Disc brakes #932540
02/19/11 07:51 PM
02/19/11 07:51 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I bought a set of spindles and brakes to put on my wagon.
I believe they are 1970 because the rotors have a separate hub for the lug nuts attached to the rotor.
Can I use a later model rotor on these spindles ?
Any help would be great
Re: 1970 B - Body Disc brakes [Re: 10secGTX] #932541
02/19/11 07:55 PM
02/19/11 07:55 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I think Scarebird and others makes a spacer now for the inner bearing to allow running the later rotor on the earlier spindle. Do the calipers ride on a caliper bracket or do they bolt right to the spindle? If they bolt on then its a 69 and back spindle, on a bracket is 70 and up.
Re: 1970 B - Body Disc brakes [Re: Sixpak] #932542
02/19/11 08:55 PM
02/19/11 08:55 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
DoctorDiff makes the bearing spacers to use the later large bearing rotor on the earlier small bearing spindle.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1970 B - Body Disc brakes [Re: moparmarks] #932543
02/20/11 08:17 AM
02/20/11 08:17 AM
BDW Online content
BDW  Online Content
Re: 1970 B - Body Disc brakes [Re: BDW] #932544
02/20/11 12:08 PM
02/20/11 12:08 PM
Texas
70Runnerdude Offline
Texas
Budget wise what is the more economiacl to convert from drum to disc on a 70 B body ? What kinda spindles and so forth ??
Re: 1970 B - Body Disc brakes [Re: 70Runnerdude] #932545
02/20/11 12:15 PM
02/20/11 12:15 PM
BDW Online content
BDW  Online Content
Re: 1970 B - Body Disc brakes [Re: 70Runnerdude] #932546
02/20/11 12:38 PM
02/20/11 12:38 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this car has late A-body discs....manual stops very well.
Coming soon!!!!
Re: 1970 B - Body Disc brakes [Re: BDW] #932547
02/20/11 03:04 PM
02/20/11 03:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: 1970 B - Body Disc brakes [Re: BDW] #932548
02/20/11 04:11 PM
02/20/11 04:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here's what you need:
http://cgi.ebay.com/ebaymotors/70-72-Mop...=item2a0dd0112d
this is all you need , sold by dr. diff to put the 73 up rotors on the 70-72 spindles , uses the same caliper set you already have and the rotors are cheaper and plentiful .
