426 hemi Lakewood bell housing #932143
02/19/11 12:54 AM
02/19/11 12:54 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Has anyone used one? I bought one and I'm just wondering if there is any mods I have to do to it or is it a direct bolt in. Thanks
Re: 426 hemi Lakewood bell housing [Re: Cape] #932144
02/19/11 01:56 AM
02/19/11 01:56 AM
If you have either the 130 or 142 tooth flywheel it is a bolt in and use, if you have a 170 (173?) tooth with the direct drive starter your SOL(solidly out of luck )I used both both brands, Lakewood and Ansens in my 1970 Cuda with a 1968 street hemi motor that had the 170 tooth flywheel. I had to switch to a 142 tooth flywheel and the gear reduction starter to use the first ansen scattershield I later switch to a 130 tooth flywheel with the 10.95 clutch and pressure plate. several things come into play, the Z bar mounts, the front bearing size and the throw out arm. All of the Z bar mounts I have seen unbolt from the stock bellhousing and bolt correctly on the scatter sheilds Both of the scatter shields I had came with adapters to move the starter and a adapter ring to insert in the front of the scatter sheild to use the small front bearing transmissions, I ran a 18 spline trannys with the large front bearings so I didn't use the adapter rings, I still have one
Re: 426 hemi Lakewood bell housing [Re: Cab_Burge] #932145
02/19/11 02:10 AM
02/19/11 02:10 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The earlier lakewoods like I have had serviced only one flywheel , 143 tooth,Gee could it be out of cert? later in the 70's they came out with the 2 position 130-143 tooth bell, Should bolt right up with no problem. As cab said the bearing retainer hole is critical , make sure it fits or get a bushing or a larger retainer. Brewer Performance or Passion have them.
Re: 426 hemi Lakewood bell housing [Re: Cab_Burge] #932146
02/19/11 02:17 AM
02/19/11 02:17 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks for the info. My flywheel is the 142 one. I dont have the bell housing yet. My starter is a mini powermaster one. I just wanted to see if there were any issues with that kind of bell housing.
Re: 426 hemi Lakewood bell housing [Re: Cape] #932147
02/19/11 03:02 PM
02/19/11 03:02 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
You will have to clearance the flanges on it if you use TTI headers with it.
