Re: six pack outboard carb adjustment
[Re: macmic87]
#931579
02/18/11 11:59 AM
02/18/11 11:59 AM
Posts: 3,916 usa
lewtot184
usa
if idle increases, that means rich and turn the screw clockwise.
wrong. if the idle increases the idle mix is too lean. back the mixture screws out (counter clockwise) about 3/4 turn from seated for a starting point.
[Re: macmic87]
#931582
02/18/11 06:08 PM
02/18/11 06:08 PM
Posts: 106 Australia
charger RTSE
Australia
I have found different articles with different opinions confusing. Installation and tuning of the six pak induction system by Jerry Binder says the opposite to the above link in the post above. Which is right which is wrong?
[Re: charger RTSE]
#931588
02/18/11 10:09 PM
02/18/11 10:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
So has the author got his instructions wrong. It looks divided on opinions. Its ineresting some say when idle increases mix is lean others say mix is rich.
Sorry Guys, I apologize,....I flubbed when I typed the air bleed lean/rich technique when I wrote that sentence, should have remembered the old addage when blocking off the air bleed. if it "sounds mean(high RPM) it's lean, if it's ragged (low rpm) it's rich" ......but regardless of the flub, the idea is to try and minimize the rise/fall in RPM when blocking the outer bleed and turning the corresponding base screw to achieve the ideal air/fuel ratio based on rpm readings, again I apologize for that flub
Mike
[Re: charger RTSE]
#931589
02/18/11 10:16 PM
02/18/11 10:16 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Yes picture of tool would be great.
https://board.moparts.org/ubbthreads/showthreaded.php?Number=5350700 So has the author got his instructions wrong. It looks divided on opinions. Its ineresting some say when idle increases mix is lean others say mix is rich.
Some items can be a matter of opinion, others are not. This discussion is not. Study and understand carb function, and you will know which is correct.
[Re: charger RTSE]
#931591
02/19/11 01:00 AM
02/19/11 01:00 AM
Posts: 3,905 Minnesota
3twos
Minnesota
I think what they are trying to say is if you block off an air bleed and the the idle increases then it is a lean condition. When you block off an air bleed you enrichen the mixture so it is lean? I would start with the outboard idle screws out 5/8 turn from seated and go from there. Then tune the outer carb since you can get at the screws with it on the engine and then switch it with the back one and adjust it while running.
Al & Sheila
[Re: DAYCLONA]
#931592
02/19/11 03:55 AM
02/19/11 03:55 AM
charger RTSE
Australia
Mike
Thanks Mike and everyone now i know which way to turn the screw. I hope others have learn't from this thread
[Re: buildanother]
#931594
02/19/11 09:55 PM
02/19/11 09:55 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I just made one out of a coat hanger. Cut it about 22" long, straightened it out & flattened one end like a small screwdriver & bent the other end 90 degees for a little twisting lever. Works just fine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: macmic87]
#931595
02/20/11 09:00 AM
02/20/11 09:00 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I have two of the same tools.Mine are SnapOn though.They made them for the 2.2 Mopar carbs and the GM carbs.They were a tight fit.They also adjust a few other tight carbs.I believe they came with 4 different ends.Rocky
Chrysler Firepower
