Page 1 of 3 1 2 3
Obtaining quench in a slant 6? #931508
02/18/11 04:03 AM
02/18/11 04:03 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I've got big block experience, but this will be my first slant 6 build. It's a 225 and I can't find much info out there (slant 6 sites) on building for quench. Anyone here done it? I think the 198 rods would help, but what about pistons? Any advice will be appreciated!
Re: Obtaining quench in a slant 6? [Re: polkat] #931509
02/18/11 10:17 AM
02/18/11 10:17 AM
maybe 2.2 turbo pistons. Go here, www.slantsix.org EDIT missed that you have been there, I'm surprised that they dont have a ton of knowledge on this. I dont even know if those heads are open or closed ch's
Re: Obtaining quench in a slant 6? [Re: RapidRobert] #931510
02/18/11 10:33 AM
02/18/11 10:33 AM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: Obtaining quench in a slant 6? [Re: RapidRobert] #931511
02/18/11 10:34 AM
02/18/11 10:34 AM
Texas
vynn3 Offline
vynn3  Offline
Texas
No closed chamber heads for slants. A few folks have made their own...
The 2.2 pistons work on the long-rod combo to increase compression and provide a better rod ratio, but don't do anything for quench.
Quench in a slant ain't gonna happen without a LOT of work and creativity.
vm
Re: Obtaining quench in a slant 6? [Re: vynn3] #931512
02/18/11 04:53 PM
02/18/11 04:53 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
It's my understanding that the heads have a very thick base, and can be milled as much as .100", which will bring them very close to closed chamber. I guess what I'm thinking is to find pistons with a somewhat positive deck height to make up the difference. I realize that much measurement and mock up would be required. Maybe the 2.2 pistons would be a start.
Re: Obtaining quench in a slant 6? [Re: polkat] #931513
02/18/11 07:44 PM
02/18/11 07:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just throwing this out, but if you mill the head .100" and run a positive deck height piston your compression will be well over 12-1.
With a 198 rod and 2.2 turbo pistons you will have a deck heght of -.025/.030, depending on whether your stock deck is unmolested or not. This will give you roughly 9.5-1 with a stock CC head and a Fel-Pro gasket. Stock is usually around 58cc.
The turbo pistons have a dish in them and do create somewhat of a quench effect.
Re: Obtaining quench in a slant 6? [Re: vynn3] #931514
02/18/11 08:19 PM
02/18/11 08:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
On the sl6 combustion chamber link, arent they showing a comparison of the older vs newer sl6 head with the newer being more like a closed chamber. 68 and later.
Re: Obtaining quench in a slant 6? [Re: Sport440] #931515
02/18/11 08:41 PM
02/18/11 08:41 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is not very much difference at all in Slant chambers from beginning to end. I always use the later model heads to get away from those oil leaking spark plug tubes.
One other small point, the Slant head was designed to work with 170 cubic inches. It was never improved when they went to the 225.
Re: Obtaining quench in a slant 6? [Re: slantzilla] #931516
02/18/11 08:50 PM
02/18/11 08:50 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
slantzilla, you said that the 198 rods and 2.2 pistons would give about 9.5:1 comp with the Fel Pros and a piswton deck of about -.025"/-.030". If the later head was milled to closed chamber, and a steel gasket (.020") was used, would this not render .045 to .050" quench, or am I missing something?
Also, excuse my ignorance, but what 2.2 pistons are we talking about here? Who sells them?
Re: Obtaining quench in a slant 6? [Re: polkat] #931517
02/18/11 09:05 PM
02/18/11 09:05 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
What are you actually trying to accomplish? A good MPG street motor or a performance build?
You have to remember that you are dealing with a very small bore here. A lot of milling on the head increases compression like crazy. Cam choice will become pretty critical so you don't build too much cylider pressure.
My motor has the head milled .065" and has the 198 rods, 2.2 turbo pistons about -.020" in the hole, and a Fel-Pro gasket. I am right under 11.5-1, and it is NOT pump gas friendly. I also run a cam with 300* advertised duration and .558" gross lift.
My pistons are KB Silvolites. They have a narrow ring on them too.
There is a deal on Wiseco pistons and K-1 rods on www.slantsix.org . When the deal started they were about the same as rebuilding a set of 198 rods and using KB pistons. Not sure how much they are now.
Re: Obtaining quench in a slant 6? [Re: polkat] #931518
02/18/11 09:21 PM
02/18/11 09:21 PM
You'd want tighter than 45-50. I think w the long rods/2.2 turbo pistons you could mill the head/block enough to get .035-.040" but you'd have to do some valve relief milling on the pistons as said to get the CR pump gas friendly. Polkat I think your plan is solid, to get an efficient /6 (which means quench) for an economy build. Holler what you end up w
Re: Obtaining quench in a slant 6? [Re: RapidRobert] #931519
02/19/11 01:43 AM
02/19/11 01:43 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Thanks Robert. I plan to research the **** out of it and I'll get back with what I find.
Re: Obtaining quench in a slant 6? [Re: slantzilla] #931520
02/19/11 08:30 AM
02/19/11 08:30 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Wow, really...??? Not that i've ever heard ov someone saying this number was better than that number, but ONE design? That blows. No offense to you slantzilla, but honestly i dont understand why anyone even bothers with these things. They are so huge and heavy, and still at best 225 cid. I can see restorations, or weird builds, but anything thats intended to run fast, or be efficient... it just seems so utterly hamstrung by the design limitations. Boost or nitrous is another matter, but N/A...???
My brother spent his new family into poverty trying to do something with his slant six in a 69 Valiant. It was neat, really neat, but even after buying the whole Clifford catalog and getting creative where that failed, it was getting beat by Neons, Conquests, Hondas, and he can definitely drive...
My Challenger definitely qualifies as a survivor... its a slant 6/3spd car, and i want to drive this thing so bad i've almost entertained the idea ov building a budget 225 for it from the numbers engine... just to save myself the swap hassles. But then i figure i wont have half the goodies he had, plus another 300lbs...
Re: Obtaining quench in a slant 6? [Re: Pale_Roader] #931521
02/19/11 10:30 AM
02/19/11 10:30 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
His first mistake was buying the whole Clifford catalog. With a few exceptions, most of Clifford's stuff is useless. Building a small CI motor is not just a throw money at it and it will be fast.
Why do I do it? Because I have had tons of big and small block cars and wanted something different. I used to park my 15 second Duster next to my buddy's 10 second 383 Demon at the track, and for every person who came and looked at his car, 10 looked at mine.
I have also run 12.0@110 in a Slant street car on nitrous.
Re: Obtaining quench in a slant 6? [Re: Pale_Roader] #931522
02/19/11 06:39 PM
02/19/11 06:39 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
You weren't talking to me, but I'll throw my $.02 in. To some people, old cars aren't all about going as fast as possible for the least amount of money. My mildly-modified slant goes as fast as I'll ever need it to. When/if if ever doesn't, I'll add a turbo.
Oh, and I prefer the SOUND of an inline six. V-8's sounded okay when I was a teenager, but every old pickup in TX has glasspacks and duals... <yawn>.
Re: Obtaining quench in a slant 6? [Re: vynn3] #931523
02/22/11 10:20 AM
02/22/11 10:20 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Oh i understand that just fine... we deal in (true, not trendy) rat rods here. Its not always about speed. But as much as Mopar guys want to wave the Mopar flag, the factory just did not give y'all much to work with here at all.
One ov the most memorable and just plain badass cars i've ever seen at the track was an early Maverick with a big Ford I-6 (and a 5-speed stick?) in it. This thing was scary fast, loud as all hell and just plain weird. Right out ov a Mad Max movie set. And i could not stop checking it out. But it was a BIG 6. 300cid seems to stick in my head, but i honestly dont remember. My brother's car had a neat sound, for a 6... big goofy header and a Borla... But i'm a V8 guy. A V8 at full howl sounds better than a chick saying 'yes'...
PS - its the glasspacks. Those got old when i was 18...
Re: Obtaining quench in a slant 6? [Re: Pale_Roader] #931524
02/22/11 10:26 AM
02/22/11 10:26 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
FWIW, a former co worker was an engineer on that 300 CID I-6 ford had in their trucks. when they developed the EFI for it, they had to detune it, because it made more power than the optional 302 V-8.....
2017 Grand Cherokee Overland
Re: Obtaining quench in a slant 6? [Re: slantzilla] #931525
02/22/11 10:31 AM
02/22/11 10:31 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I was not there when he was planning this thing, i was brought into the picture when he got desperate enough to actually ask his Mopar guy brother why his hotrod was getting embarrassed by slow imports. I did port the head though, without going nuts there i can say at least that part was decent. Maybe you've gotta REALLY hog those things out...???
He also bought a Comp cam, the big solid in the catalog, which i tried to steer him away from. Not knowing anything about slant sixes then, i just thought i'd compare it to what i'd expect from a 225cid V8. It still came up short. Something in that combo was drastically wrong.
I have also run [Email]12.0@110[/Email] in a Slant street car on nitrous.
Yup. His Valiant got the stares, and when the hood was open the crowds would form. If anything he definitely had that six looking pretty cool. Painting it bright slime green probably helped...
I'm sure my Challenger would stop traffic at a show or in the pits with its six, but i just cannot handle a slow car (or that sound i suppose).
Curious though... How much power can be made from a basic budget slant six build...??? Lets say port the head, big cam (a good cam, maybe a custom), quench, maximum pump-gas compression, well-designed header (i'll make my own) and race exhaust, a good intake and carb. No NOS or boost. Could you make 300HP N/A without getting really tricky or pricey...??? In a 2800lb car with a 4speed and gears that might not actually be embarrassing...
Re: Obtaining quench in a slant 6? [Re: polkat] #931526
02/22/11 01:24 PM
02/22/11 01:24 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If you plan to do more research,
you might consider writing a letter to
Willem Weertman
who is now retired
and seems to want to
pass on knowledge to a new generation
http://www.allpar.com/corporate/bios/weertman.html
notice the bit about the Slant 6 diesel engine project
sample quote
Q: The various programs to modify the Slant Six that I have read include things such as a turbo charged version and another aluminum version and a fuel-injected version, is there anything that you can tell me about those and what instigated them and why they were not pursued?
I think I mention both the diesel and turbo versions in the book. The diesel version was a pretty neat program when we were working on that one. It was quite well developed; we had a 4-cylinder version of the Slant Six engine for use, it was a turbo-charged 4-cylinder diesel version of the Slant Six engine. It was no longer slanted though. I’m sure it was upright. But the diesel version of the Slant Six was slanted.
That program died when the interest in diesel engines in the U.S. died following the unsuccessful launching of General Motors diesel version of an automotive engine. That gave the diesels a bad reputation in the field and the market dried up and with that we quit our diesel program. That cessation of our own diesel Slant Six program was a decision by Lee Iaccoca. He figured the market wasn’t there and we shouldn’t be spending any money in that direction and he was right and we just stopped working.
Re: Obtaining quench in a slant 6? [Re: 360view] #931527
02/22/11 10:14 PM
02/22/11 10:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
300 is doable, but I'm not sure I would call it a "budget" build. 300 N/A is also getting right on the ragged edge of a streetable Slant.
More is not always better when porting a Slant head. Be careful when choosing valve sizes too. What makes for great flow on a flow bench does not necessarily work on an engine because of the small bore.
Dig around on www.slantsix.org and you will find an engine build matrix that details many of the motors we have done.
Page 1 of 3 1 2 3
