Epoxy used in intakes & ports
#931198
02/17/11 05:16 PM
02/17/11 05:16 PM
Posts: 290 Manitoba, Canada
liteweight
Manitoba, Canada
I want to do some flow work inside an old Rat Roaster X ram for a Hemi & I am wondering what you guys are using for epoxy as a filler.
Liteweight Daryl
68 Hurst LO Hemi Dart
70 hemicuda 4 spd. R code owned since 76
70 GTX 4 spd. 21,000 orig. miles
55 Ford F100 chopped,slammed,bagged & supercharged
96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
Re: Epoxy used in intakes & ports
[Re: Stanton]
#931200
02/17/11 05:58 PM
02/17/11 05:58 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Splash Zone. Highly recommended by Darrin Morgan. Great with gas but needs coated with a clear coat if running straight alcohol. Not to be used on ex ports.
[Re: S/ST 3040]
#931202
02/18/11 02:09 PM
02/18/11 02:09 PM
liteweight
Manitoba, Canada
Thanx guys. I did some searching last night & found a few places that carry the Splash Zone Epoxy Z Spar A 788. Price varies, & the cheapest I found is Go2Marine @ $58.00 for 2 quarts. It's more than I need, but I quess I can keep the left over in my boat as an emergency rock scraping repair.Now all's I need is a boat Liteweight Daryl
[Re: pittsburghracer]
#931204
02/18/11 03:47 PM
02/18/11 03:47 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I am having a guy do some uNporting work ... putting dams in ... probably will have to be brazed in.
[Re: liteweight]
#931205
02/18/11 03:57 PM
02/18/11 03:57 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Liteweight Daryl
http://www.goodson.com/store/template/pr...8eab314cc275d8b
This is splash zone in a Goodson container. About smallest amt. you will find available.
I use a certain brand of Concrete epoxy for most of my stuff. Adheres a bit better than Splash Zone/Moroso etc. It's the closest stuff I've found to Belzona 1111 Super metal out there in an affordable quantity.
[Re: RyanJ]
#931206
02/18/11 04:05 PM
02/18/11 04:05 PM
BradH
How does this new(?) stuff hold up to alcohol in the fuel? It was the 10% ethanol in today's pump gas that "rubberized" the Moroso epoxy I'd used in my intake.
