Ebody Ebrake Mounting Gaskets Debate.. What did U have? #931025
02/17/11 11:40 AM
02/17/11 11:40 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
Was getting ready to install the ebrake assembly on my 70 Challenger and realized I have no gaskets for mounting it. Jim Filmore and I have been emailing this morning and he has not had any request for them but is willing to help. On my old unit, there appears to have been a rectangle gasket (the tan residual material on the mounting bracket), however the manual mentions two sealing washers for the studs.
So what did you have and what did you do to seal your e brake mounting bolts?
Joe
65 Barracuda
70 Challenger
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: jrwoodjoe] #931026
02/17/11 11:42 AM
02/17/11 11:42 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Mine had two circular white foam gaskets. New ones were included in the kit I got from Jim.
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: burdar] #931027
02/17/11 12:06 PM
02/17/11 12:06 PM
Tenn.
Tenn.
The ones in Jim's kit are for the 4 speed clutch bracket. If your car is an automatic, then you would have had those left over and been able to use them. I have an extra master cylinder foam gasket that will not be used and am thinking of just making one out of that since I'd like to try to put the dash in today.
Joe
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: burdar] #931028
02/17/11 12:10 PM
02/17/11 12:10 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Joe I used a rectangular piece of thin white styrofoam similiar to the piece under the gas pedal.
Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: jrwoodjoe] #931029
02/17/11 12:24 PM
02/17/11 12:24 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
The tan residual material is seam sealer from the corner...I found two round circles on most of my cars, but I haven't dealt with a lot of 70's
CHECK OUT MY NEW WEB SITE !
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: 19cuda73] #931030
02/17/11 12:43 PM
02/17/11 12:43 PM
Tenn.
Tenn.
That's what I did. Made one out of scrap.
Re: Ebody Ebrake Mounting Gaskets Debate.. What did U have? [Re: jrwoodjoe] #931031
02/17/11 01:20 PM
02/17/11 01:20 PM
California
1970mopar Offline
1970mopar  Offline
California
Have owned 25+ e-bodies and all have had two round gaskets over the studs.
Back when JIM first started making gaskets these were on his original gasket list if I recall.
