72 Road Runner Rallye Dash Wiring Question #930698
02/16/11 10:15 PM
02/16/11 10:15 PM
Hawaii
RRGTX72 Offline OP
RRGTX72  Offline OP
Hawaii
I am in the process of putting my dash back in my car, and I have an extra wire and don't know exactly where it goes. I have a Heavy Gauge Red wire that goes to the Alt gauge, but I also have a Heavy Gauge Red with White Stripe wire. Do they both go to the Amp Gauge or does one of them go to another gauge? Any help would be greatly appreciated.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930699
02/16/11 10:17 PM
02/16/11 10:17 PM
Hawaii
RRGTX72 Offline OP
RRGTX72  Offline OP
Hawaii
Here is the pic of the wire.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930700
02/16/11 10:18 PM
02/16/11 10:18 PM
Hawaii
RRGTX72 Offline OP
RRGTX72  Offline OP
Hawaii
Here is another pic.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930701
02/16/11 10:19 PM
02/16/11 10:19 PM
Hawaii
RRGTX72 Offline OP
RRGTX72  Offline OP
Hawaii
Here is a pic of the cluster so you know what kind of gauges are there.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930702
02/16/11 11:19 PM
02/16/11 11:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
wiring diagrams... link
Re: 72 Road Runner Rallye Dash Wiring Question [Re: screamindriver] #930703
02/16/11 11:47 PM
02/16/11 11:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
normally extra accesories sources what it sucks power from batt
however, I have seen those extra thick wires on station wagons and extra equipments options ( Police, cabs ) not really on a pretty much standart vehicle.
I can't recall if power windows harness gets that wire.
you should eb able to find around the other end of that wire.
It should be hooked on black side of ammeter, not on red side.
Where is BTW, the back wire to the ammeter ? ( the thick one similar to the red ) I can't see it attached to your cluster. Red one attachs to the RED post ( labeled ) and black to the unlabeled ( including the clock one and any other extra wire what sucks power )
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930704
02/17/11 01:00 AM
02/17/11 01:00 AM
Shoreline, Washington
72roadrunnergtx Offline
Does your car have power windows? Appears to be the 10 gauge power feed for the 30 amp circuit breaker mounted to the top of the fuse box. The ring connector would connect to the alternator side (black wire) of the amp gauge.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 72 Road Runner Rallye Dash Wiring Question [Re: 72roadrunnergtx] #930705
02/17/11 01:24 AM
02/17/11 01:24 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Just some advice. Since you are wiring it up, Id bypass the amp meter gauge. Its almost a necessity and the factory probably shouldnt have wired it as such. Mad Electrical has a write up on the subject.
I did it to my car (72RR) and I am very glad I did.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: 72roadrunnergtx] #930706
02/17/11 02:00 AM
02/17/11 02:00 AM
Hawaii
RRGTX72 Offline OP
RRGTX72  Offline OP
Hawaii
Yes it has Power Windows. So the red with white stripe wire hooks up to the black side of the Alt gauge, and the Solid red wire hooks up by itself?
Why should I bypass the Alt gauge all together? Should I buy an aftermarket one? What problem did you occur with it wired to the dash?
Thank you all for your help.
Re: 72 Road Runner Rallye Dash Wiring Question [Re: RRGTX72] #930707
02/17/11 10:35 AM
02/17/11 10:35 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[Why should I bypass the Alt gauge all together? Should I buy an aftermarket one? What problem did you occur with it wired to the dash?
[/quote)
Go to madelectrical.com
I believe the article I am talking about is under electrical tech.
Id give you a link, but for some reason the site isnt loading for me right now.
