Auto Tranny Fluid for a '65 Valiant/Barracuda?? #930577
02/16/11 09:06 PM
02/16/11 09:06 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
My book says use Dextron or Dexron Type A.
I don't believe that is manufactured anymore.
Does anyone know what I should use?
Thanks!
Tim..
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: cuda_tim] #930578
02/16/11 09:25 PM
02/16/11 09:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Type F works fine.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: cuda_tim] #930579
02/16/11 09:41 PM
02/16/11 09:41 PM
I'd suggest Dextron III. I think that's the latest version of it.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: RapidRobert] #930580
02/17/11 01:21 AM
02/17/11 01:21 AM
Central TX
roe Offline
roe  Offline
Central TX
DexronIII is backwards compatible
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: roe] #930581
02/17/11 01:33 AM
02/17/11 01:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And since I'm old school & have run Type F in every Torqueflite I've ever built...... Newer Dexron has higher lubricating additive %.. Type F has less than standard old Dexron/Type A which means the clutches grab better...... B&M use to sell a special fluid they called "Trick Shift" it was Type F with blue dye in it...
Stumpy may be Grumpy... But he's right...
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: 1_WILD_RT] #930582
02/17/11 09:48 AM
02/17/11 09:48 AM
On a fresh build from scratch(N) I'd go w F but to add some which I gathered was what he had in mind would you want to mix the two?
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: RapidRobert] #930583
02/17/11 11:55 AM
02/17/11 11:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Done it many times..
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: 1_WILD_RT] #930584
02/17/11 09:00 PM
02/17/11 09:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Go to a convenience store, The ATF they sell is Type A, the original Dexron, just read the label. Usually it's from Coastal. As for type F, the only time I tried that rick I lost all the friction material off my clutches and had to rebuild the trans, so be wary.
Don't be the exception.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: Supercuda] #930585
02/18/11 12:05 AM
02/18/11 12:05 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I used type F for years with no problems and so have a bunch of other guys I know. If you lost all the friction material then the clutches were badly made to begin with.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: stumpy] #930586
02/18/11 12:10 AM
02/18/11 12:10 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, that was the problem, I don't think so Tim.
I did a fluid and filter change on a perfectly running PB 727. Next day it starts slipping bad, barely got it home. Coincidence? I don't think so, BTW OEM friction material and every clutch was bare, if it was one or two, or even one drum's worth I might have thought otherwise. But when all of them go in a matter of an hour or so's drive time it's not the friction material.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: Supercuda] #930587
02/18/11 12:27 AM
02/18/11 12:27 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Could the combination of fluids have caused the clutches go?
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: Fat_Mike] #930588
02/18/11 12:51 AM
02/18/11 12:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sorry that is impossible to believe for the fluid to do that in one day. There isn't that much difference in the older types of fluid. I've been building transmissions since the 60s and never have ever had that happen or seen it happen.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: stumpy] #930589
02/18/11 12:54 AM
02/18/11 12:54 AM
I agree, it wasn't the fluid (or combo thereof) that stripped em
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: cuda_tim] #930590
02/18/11 12:12 PM
02/18/11 12:12 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Thanks!
Tim..
For good and bad, its no longer available due to improvements and volume of sales.
The bad part is there's too many new ATFs that seem to be maybe kindof backword compatible and its darn confusing. About 2/3 way down in this 2002 Motor Magazine article they summarize the differences to date (then).
Type F has the opposite characteristics than most of the other fluids. Many racers have used it in torqueflites for that reason. Since you're asking about stock replacement, lets move on to the Dexron family.
In brief, my conclusions are the 'best' most backword compatible ATF for a plain Dexron spec'd torqueflite are:
Dexron VI (synthetic and generally most expensive)
Synthetic spec'd as Dex III replacement
Dexron/Mercon (least expensive)
Multi-purpose (usually least expensive, but IMO these are a crap shoot and I'm not a gambler)
The newer ATFs usually have better oxidation resistance and low temperature viscosity. Whatever you buy, check the can (uh bottle) or the manufacturer that its compatible with Dex II or earlier.
Some bottles say compatible with all Chrysler transmissions. This is a bad sign. The needs of all Chrysler transmissions are not the same. Many do not take Dex III and earlier. There's long articles on this (see for example Allpar.com). The big change seems to be when ATF+3 and +4 were developed specificly for the new transmissions with control modules.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: RapidRobert] #930591
02/22/11 08:19 PM
02/22/11 08:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Let me lay it out for you and you tell me what the problem "really" was.
I did a fluid and filter change, which means I dropped the pan. I inspected the pan for anything out of the ordinary, there were some minor black deposits, minor as in I've seen them in any number of other fluid and filter changes I have done, before and since. I cleaned the pan, changed the filter, adjusted the bands, reinstalled the pan, filled the trans, let it idle in neutral to top off the system and inspected for leaks. Next day, I go to work, no issues, I finish work drive home and about halfway home the trans starts slipping, bad. I limp home (maybe 5 miles total). Drop the trans, pull it apart and NONE of my clutches have any friction material anymore.
This trans probably had well over a 100,000 miles on it at the time, I don't know for sure since I swapped it in to replace the stick I had, but more than 20k miles I put on it.
What was the problem, if not the fluid change? I don't care to experiment again since I really do not want to have to rebuild another trans.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: Supercuda] #930592
02/22/11 09:08 PM
02/22/11 09:08 PM
Not sure just didn't think the fluid would have done it, esp that fast. That had to have been a bad deal
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: RapidRobert] #930593
02/22/11 11:08 PM
02/22/11 11:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If it'd been just some clutches, or even a drum's worth I'd probably agree, but all of them, both drum's worth. I cannot remember what the bands looked like, I know I replaced them too. Heck, it's been probably 17 years now. As it stands, i am not 100% sure and am not willing to retry it.
Re: Auto Tranny Fluid for a '65 Valiant/Barracuda?? [Re: Supercuda] #930594
02/23/11 12:42 AM
02/23/11 12:42 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might have gotten some contaminated fluid but there is no way any regular trans fluid would cause that problem. As I said I've been doing transmissions since the mid 60s and type F will not cause that kind of reaction. Go with dex3 and you should be good.
