Re: 5.9 cummins swap into car
[Re: buildanother]
#930336
02/16/11 01:42 PM
02/16/11 01:42 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
There's the 70-72 monte carlo on the tube.
![](/ubbthreads/images/graemlins/iagree.gif)
I told Feets to put one into his new Sea body too. ![](/ubbthreads/images/graemlins/devil.gif)
[Re: bucket]
#930337
02/16/11 01:56 PM
02/16/11 01:56 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
The cummins is an awesome motor, but it is way too big and heavy for a car. Yes, it's been done but there is no good reason unless it's just for the novelty. A person would be way better off using a PSD or Duramax as they are far more compact and lighter. The front suspension of my 1 ton trucks isn't really up to the weight of a Cummins ISB. Funny, people here often espouse the virtue of a small block over a big block for handling....can you imagine the handling using a motor that is 400 - 500 lbs heavier (and without all the aftermarket aluminum goodies available to make it any lighter)? ![](/ubbthreads/images/graemlins/Twocents.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DaytonaTurbo]
#930340
02/16/11 03:25 PM
02/16/11 03:25 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Shipping weight on a 6BT is 1200 lbs. That's like having two small blocks under the hood. Try this: http://www.4btswaps.com/forum/index.php
[Re: bucket]
#930341
02/16/11 07:18 PM
02/16/11 07:18 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi yes it has been done . saw a early nova with a stock 12v in at cicel co dragway last year . mid 11 sec . ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: calrobb2000]
#930342
02/16/11 07:25 PM
02/16/11 07:25 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
mid 11 sec .
Stock 12V and goes 11s? Ive gotta raise the flag on that....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
