Re: 5.9 cummins swap into car
[Re: buildanother]
#930336
02/16/11 01:42 PM
02/16/11 01:42 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
There's the 70-72 monte carlo on the tube.
I told Feets to put one into his new Sea body too.
[Re: bucket]
#930337
02/16/11 01:56 PM
02/16/11 01:56 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
The cummins is an awesome motor, but it is way too big and heavy for a car. Yes, it's been done but there is no good reason unless it's just for the novelty. A person would be way better off using a PSD or Duramax as they are far more compact and lighter. The front suspension of my 1 ton trucks isn't really up to the weight of a Cummins ISB. Funny, people here often espouse the virtue of a small block over a big block for handling....can you imagine the handling using a motor that is 400 - 500 lbs heavier (and without all the aftermarket aluminum goodies available to make it any lighter)? Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DaytonaTurbo]
#930340
02/16/11 03:25 PM
02/16/11 03:25 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Shipping weight on a 6BT is 1200 lbs. That's like having two small blocks under the hood. Try this: http://www.4btswaps.com/forum/index.php
[Re: bucket]
#930341
02/16/11 07:18 PM
02/16/11 07:18 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi yes it has been done . saw a early nova with a stock 12v in at cicel co dragway last year . mid 11 sec .
[Re: calrobb2000]
#930342
02/16/11 07:25 PM
02/16/11 07:25 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
mid 11 sec .
Stock 12V and goes 11s? Ive gotta raise the flag on that....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
