aluminum verses standard flywheel #930180
02/16/11 01:13 AM
02/16/11 01:13 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
will aluminum work ok for cruising or is it best just for high rpm engines,what are the pros and cons?
Re: aluminum verses standard flywheel [Re: rhad] #930181
02/16/11 01:27 AM
02/16/11 01:27 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
A car with an aluminum flywheel will stall easier at lower RPM.
Re: aluminum verses standard flywheel [Re: rhad] #930182
02/16/11 09:13 PM
02/16/11 09:13 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
What engine/body style?
I did this conversion last winter. I picked up .6 at the track, but I did some other mods along with the aluminum flywheel. What I noticed after the install is how fast the engine rev's. Real snappy. I noticed NO difference in driving on the street, but my engine makes good torque and horsepower. If you have a chance to get an aluminum wheel, I'd do it. If it doesn't work, you can always resale it.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: aluminum verses standard flywheel [Re: 68LAR] #930183
02/16/11 11:33 PM
02/16/11 11:33 PM
QLD Australia
Keith Black® Offline
QLD Australia
Some manufacturers say if you're running a dual disk setup, often the weight of the clutch assembly makes up for weight savings in the flywheel.. i.e. net~net no difference.
Interesting to hear about improvements in throttle response tho, cool.
Darren Beale
Keith Black Racing Engines®
Re: aluminum verses standard flywheel [Re: Keith Black®] #930184
02/17/11 01:22 AM
02/17/11 01:22 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I have one in my duster,422 ci small block. Is super fun to drive and yes throttle response seems instantaneous.
Re: aluminum verses standard flywheel [Re: dezduster] #930185
02/17/11 03:53 AM
02/17/11 03:53 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Interesting to note, I found a website that listed weights of the clutches for McLeod and their twin disc RSX clutch was 30 lbs while their somewhat comparable single 10.5 clutch set was 32.
The difference you'll see with an aluminum flywheel is the engine will accelerate faster (even under load), but will require more feathering of the clutch to take off from a dead stop. Also, if you're having issues bogging off the line in a drag car, going to aluminum will make it worse. Not enough stored energy to get the car moving.
Typically see aluminum in road race cars where the engine is required to accelerate and decelerate quickly.
Re: aluminum verses standard flywheel [Re: dodgeboy11] #930186
02/17/11 04:25 AM
02/17/11 04:25 AM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I LOVE the aluminum flywheel in my Challenger!! If I had the option I'd totally would do it again!!
Stock 440 Magnum with headers and intake/carb, OD A-833 and a 3.23 LSD.
Best of 13.9 @ 102 with this combo on crappy street tires.
Woooooo!!!!
