Re: Lucas oil additive?????
[Re: ahy]
#930010
02/16/11 12:56 AM
02/16/11 12:56 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
... I understand from several tests posted here that it lacks anti-foam additives and can contribute to foaming and lube problems on high speed engines....
To me that huge lack of quality and performance questions the whole product line.
[Re: autoxcuda]
#930011
02/16/11 03:03 AM
02/16/11 03:03 AM
Posts: 5,270 Missouri
MY340
Missouri
I used it with regular gear oil in a 100,xxx mile 4spd tranny to quiet it down and it worked great. Plus it slowed any leaks you would expect from a 38 yr old tranny that hadn't ever been rebuilt. I think I would use it on a 75,xxx mile plus engine but not a newer engine.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#930012
02/16/11 03:07 AM
02/16/11 03:07 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I saw an analysis of the Lucas oil stabilizer that said it was almost 100 percent petroleum base stock, no additives in any significant amount. In other words a waste of money.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: abc440]
#930014
02/16/11 10:49 AM
02/16/11 10:49 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I am not going to say anything for or against the Lucas oil additive. I will just state the following facts. You make up your own mind. I worked for a company that has the second largest private fleet of Class 8 trucks in the country, second only to Walmart. Manufacturers are always using our fleet as a test bed. Standard Operating Procedure when changing the oil on each tractor is to send the oil out to a lab for analysis. After 1 year analyzing the oil when Lucas was used, the company made Lucas standard as part of the Preventive Maintenance Program. I had a car with a SBC LS-3 engine. After adding Lucas, the normal operating temperature dropped 5°. That is all....
[Re: BigBlockMopar]
#930016
02/16/11 07:30 PM
02/16/11 07:30 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
There was a thread a couple weeks ago in the Race section about Lucas additive in a dyno pull on a new motor. They made a couple pulls and the oil pressure started bouncing around. They pulled the plug and foam drained out of the pan. They replaced it with straight Brad Penn oil and the foaming went away. Use good oil to start with and leave the additives for the suckers with too much money.
[Re: slantzilla]
#930017
02/17/11 03:28 AM
02/17/11 03:28 AM
autoxcuda
So Cal
Lucas is pour oil thickner. Like adding 40wt gear oil. No extreme pressure lubricant or acid reducing properties.
Motor oils are a blend. They all have additives like the zinc they took out of the Motor oil. And all in different proportions.
[Re: bobs66440]
#930022
02/17/11 02:02 PM
02/17/11 02:02 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I've used it on an old tired SB Ford that was oil fouling plugs. I was amazed, it cleaned the plugs up nice. I've also seen the tests where it foams up. In the end, I think I would use it as a last resort for an engine that has little left to lose. On a good engine I would just use a good quality oil.
Hey Bob..... Hows the 440 running since you cured the oil smoke problem? I remember that you had the intake off and that you replaced the valley pan and gaskets. Hope that everythings running tip top.
[Re: Kern Dog]
#930023
02/17/11 02:32 PM
02/17/11 02:32 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Hi, thanks for asking. I only drove it 100 miles or so after I fixed it but it went well...then had to park it because winter crept in. I've been putting in a new interior for the last month or so. Hoping to have it done within the next few weeks Hopefully the snow will be over by the end of March and I can get it back on the road again.
