which carpet color do I need #929892
02/15/11 10:24 PM
02/15/11 10:24 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
1970 bee has tan or saddle interior depends on who's codes I look up which code on the build sheet is for carpet?? thanks ozz
Re: which carpet color do I need [Re: ozz383] #929893
02/17/11 12:09 PM
02/17/11 12:09 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
nobody?
Re: which carpet color do I need [Re: ozz383] #929894
02/17/11 02:35 PM
02/17/11 02:35 PM
Maryland
glenngomango Offline
Maryland
My 70 Cuda has a T5 tan interior and the carpet is tan as well.
It is a very original car but the carpet was replaced at some point
Re: which carpet color do I need [Re: ozz383] #929895
02/17/11 02:44 PM
02/17/11 02:44 PM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
It's the main color of the interior or the 'second' color if a two tone interior. Same color for instrument panel, steering wheel, and headliner.
But not always, there are some issues with burnt orange and 4-speeds where they got black carpet (at least for a while).
Re: which carpet color do I need [Re: ozz383] #929896
02/17/11 02:46 PM
02/17/11 02:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
depends on who you ask.
Also, depends if it's 4 speed versus auto.
my old 70 Bee was 4 spd , blue int and blue carpet.
my old 1969 GTX 4spd was also blue int + blue carpet
all the books say all 4 spd cars were black carpet regardless of interior color
Re: which carpet color do I need [Re: gtx6970] #929897
02/17/11 02:50 PM
02/17/11 02:50 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
mine has been replaced as well. it is an auto. trim code is m6t5.car is EV2.I guess my concern is the different shades of saddle that the carpet is made of not sure of which one ic "correct". thanks ozz
Re: which carpet color do I need [Re: gtx6970] #929898
02/17/11 03:08 PM
02/17/11 03:08 PM
Vicksburg, MI
Vicksburg, MI
Can you scan that info and post? I've been trying to figure this out forever. The 'Color and Trim selector' info achived at Hamtramck-Historical.com says nothing about 4-speeds, just that 'carpet, steering column, dash, and headliner are main or second color'.
Most 4-speeds I see are colored carpeting; the main problem area is 1970 burnt orange interiors with 4-speeds seem to be black carpet about half the time (my St. Loius convert is black carpet and 4-speed as well).
Also, I don't see where this ever shows up on a build sheet...if so, what line is it on?
Re: which carpet color do I need [Re: coffeeman383] #929899
02/17/11 03:43 PM
02/17/11 03:43 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
My 70 GTX is a 4 speed car and it came with burnt orange carpet. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: which carpet color do I need [Re: rattler] #929900
02/17/11 04:31 PM
02/17/11 04:31 PM
Vicksburg, MI
Vicksburg, MI
Rattler- Which plant? Mine is G (St. Loius).
Ozz- Try Dave Walden at ECS...it seems he added some insight on carper color last time this came up.
Re: which carpet color do I need [Re: coffeeman383] #929901
02/17/11 07:51 PM
02/17/11 07:51 PM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
thanks for the info!! ozz
Re: which carpet color do I need [Re: rattler] #929902
02/17/11 08:02 PM
02/17/11 08:02 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My 70 Road Runner is a 4 speed car with burnt orange interior and it came with BLACK carpet.
Nautilus Racing-
Re: which carpet color do I need [Re: Chris2581] #929903
02/18/11 09:14 AM
02/18/11 09:14 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
My GTX was built in St. Louis, my car has the white-burnt orange interior. The seats and door panels are white and everything else is burnt orange.
