RT ramcharger hood and 440 6 pack
#929404
02/15/11 02:29 AM
02/15/11 02:29 AM
Posts: 9 Herrin,Illinois
funny662
Herrin,Illinois
car has 440 single 4 barrel-ramcharger hood and ram air ducting to air cleaner. Whena 6 pack is installed-will the ramcharger ducting still fit/align with the air cleaner so the hood still shuts properly? I am under the impression the dual scooped ramcharger Bee/RT hood never came factory with a 440 6 pack. I figure there is a reason that combination was not available and may be why they used the lift off hood with the 6 pack Im talking Coronet RT
Re: RT ramcharger hood and 440 6 pack
[Re: funny662]
#929405
02/15/11 02:38 AM
02/15/11 02:38 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
In 70 the Ramcharger hood was available with a 440-6.. just use the standard filter assembly & you'll be fine...
[Re: migsBIG]
#929409
02/15/11 01:36 PM
02/15/11 01:36 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Yes the '70 Superbee/Coronet R/T was available with the optional 440-6 as well as the optional (standard on Hemi) Ramcharger Hood. There are two bases; one with a shield and one without but the heights are the same (unlike the 4bbl ones which had different heights for 383 vs. 440). Ramcharger ductwork not in place yet. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 69 RT ramcharger hood and 440 6 pack
[Re: DPelletier]
#929411
02/16/11 02:09 AM
02/16/11 02:09 AM
funny662
Herrin,Illinois
I assume NA---not available S----standard E----??????
I also thought power front disc brakes were standard on a 69 RT and NOT available on a super bee Getting an education here----and I truely appreciate the info thanks.Bryan Bennett
[Re: DPelletier]
#929418
02/16/11 10:22 PM
02/16/11 10:22 PM
Posts: 1,495 Fort Workin Tx
Day2Runner
Fort Workin Tx
throw in with all that said RR and GTX like super Bees and R/Ts in 69 had to different AG/RC air cleaner bases the 383 RR/SB version had a longer neck the 440 GTX/R/Ts had a shorter neck for a stock set up so then the factory knew they needed two differnt bases due to the B RB blocks I let the hood dowm nice and easy FWIW and then
