Best wheel base length #928719
02/14/11 03:12 PM
02/14/11 03:12 PM
Canada BC
Steve Barton Offline OP
Canada BC
I have a 71 Valiant with a 110" wheel base and I am going to replace my main leafs to help with spring wind up. since they are a mile long from center support to rear shackle I am going to shorten it a little and lower the car as well.
My Q is should I also move the wheel base back an inch to give me more clearance for a larger tire or would it affect my weight transfer to much. What is a desired wheel base for drag racing.
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
Re: Best wheel base length [Re: Steve Barton] #928720
02/14/11 03:39 PM
02/14/11 03:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would just switch to cal tracs and order the monoleafs at -1 to lower the car.The futher forward the rear axle is is better for racing improves weight transfer.But I have moved mine back a 1/4 in to help clear 295/65/15 drag radials and have 1.40 60fts.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Best wheel base length [Re: Steve Barton] #928721
02/14/11 08:51 PM
02/14/11 08:51 PM
gregsdart Offline
gregsdart  Offline
Don't forget the driveshaft length. There must be a way to move the whole driveline back a certain amount. If you can find out how to move the motor say 1/2 inch, then you can probably go the full inch and still not hurt the weight distribution much.
If it isn't feasible to move the motor, I would still consider moving the axle back anyway. If you get good weight transfer, the car doesn't care how much is on the front Vs rear.
I went from 50/50 to 52.5 front 47.5 rear and was really worried that it wouldn't work there. Works great. However you have to have enough torque to maintain that weight transfer. Bigger tires can overcome this, and going faster (more torque) will help as well.
Re: Best wheel base length [Re: Steve Barton] #928722
02/14/11 10:00 PM
02/14/11 10:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would like to move the axle forward but that would
take cutting the quarter panels for tire clearance
Re: Best wheel base length [Re: MR_P_BODY] #928723
02/14/11 11:00 PM
02/14/11 11:00 PM
Canada BC
Canada BC
I am running the Cal tracks now and I will be doing the rear suspension next year with ether 3 or 4 link. its just to much work for one year I have gone all out on the front end and have built a R3 416 cubes. on paper 650 Hp and 550 plus in Tq. Plus I have a 250 shot of Nos on top of that. My thought was the bigger the tire the better this is a 4 spd with 4.88 gears, I also have 4.56s I guess I could try moving the axle back for now and re think it next year.
Re: Best wheel base length [Re: Steve Barton] #928724
02/14/11 11:13 PM
02/14/11 11:13 PM
ohio
6440nssa Offline
6440nssa  Offline
ohio
Cut the dam quarter panel, it's a drag race not a car show. It seems like people are more concerned about dumb [Edited by Moparts - Family Friendly Site - Keep it clean] than building a better race car, going faster, or winning races. move the axel forward and cut the quarter.............
sean dornan
Re: Best wheel base length [Re: 6440nssa] #928725
02/14/11 11:23 PM
02/14/11 11:23 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Steve
I moved my rear back 1" and had to cut about 1/2 inch off the front of the 1/4 to fit the 29.5 m/T's I run.
Todd
