68 Charger instrumnet Cluster at home restoration #928619
02/14/11 09:36 AM
02/14/11 09:36 AM
NC
Sixt8Chrgr Offline OP
NC
I have my instrument cluster out cleaning the lenses gauge faces and bulb replacement, and while the cluster is out I am fixing some old hack jobs that were done to the wiring harness. While the cluster is out should I replace the voltage limiter and are there any other things I should do to the cluster while it is out?
Thanks!
Re: 68 Charger instrumnet Cluster at home restoration [Re: Sixt8Chrgr] #928620
02/14/11 10:00 AM
02/14/11 10:00 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
If you're not looking to 100 point restoration, then get the decal kit from Performance Car Graphics. Dave makes a very nice and affordable gauge face kit (decals). I have done many Charger clusters and they all look great. Also, check all your gauges for any loose retaining nuts.
Troy
Houston Mopar Connection Club
Re: 68 Charger instrumnet Cluster at home restoration [Re: hemi68charger] #928621
02/14/11 10:57 PM
02/14/11 10:57 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
You will do better to use a 5ohm resistor to replace the voltige limiter. You can pick one up at radio shack for about a 50 cents and if will be more acturet than the orignal one.
Re: 68 Charger instrumnet Cluster at home restoration [Re: Sixt8Chrgr] #928622
10/04/11 12:55 PM
10/04/11 12:55 PM
Houston, Tx
Houston, Tx
Hey Bill,
Here's my bench test setup I made.
Troy
