I have my instrument cluster out cleaning the lenses gauge faces and bulb replacement, and while the cluster is out I am fixing some old hack jobs that were done to the wiring harness. While the cluster is out should I replace the voltage limiter and are there any other things I should do to the cluster while it is out?
Thanks!
