Re: a 833 4 speed...no reverse or just out of adjustment? [Re: Dart6pak] #928385
02/16/11 07:50 PM
02/16/11 07:50 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
From your desceiption it seems to me that your cover is not aligned properly.The clearance between the 1/2 and reverse is too close causing a binding. Before you take it to a shop try this. Loosen the cover bolts and put the trans in reverse--this will set the clearance --with the trans in reverse retighten the cover bolts .
This sounds like what it is...
There is a step that is easy overlooked in the manual that you install one bolt in the cover; shift it into reverse and adjust the cover until a slight drag is felt in the revers lever...
I agree with the others, take the rods off and shift each rod one by one and make sure they engage w/o the shifter
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: Dart6pak] #928386
02/16/11 09:18 PM
02/16/11 09:18 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
.... Before you take it to a shop try this. Loosen the cover bolts and put the trans in reverse--this will set the clearance --with the trans in reverse retighten the cover bolts .
Exactly!
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: 68LAR] #928387
02/16/11 10:15 PM
02/16/11 10:15 PM
kansas city, mo
rave_12000 Offline OP
kansas city, mo
again, loosening all bolts and readjusting cover did not work. also, if not clear, i tried to get it into reverse with all levers removed. it is just simply not going into reverse. gotta be inside tranny.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928388
03/23/11 01:26 PM
03/23/11 01:26 PM
kansas city, mo
kansas city, mo
ok...was going to haul to shop today, but he is not available.
I am 100% certain this is not a shifter or linkage rod issue .
"The first and second shifter fork needs turned around."
Is this "fork" inside the case?
thanks.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928389
03/23/11 11:03 PM
03/23/11 11:03 PM
kansas city, mo
kansas city, mo
got r did. cover was misaligned. made sure to loosen all bolts AND 1/2 and 3/4 rod nuts. I think I had a little more patience this go around since I wasn't laying on ice in 30 degree weather. thanks for the help.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928390
03/24/11 11:25 AM
03/24/11 11:25 AM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
