a 833 4 speed...no reverse or just out of adjustment? #928365
02/13/11 11:53 PM
02/13/11 11:53 PM
kansas city, mo
rave_12000 Offline OP
kansas city, mo
got a 833 4 speed that i just put in my 70 challenger. all gears work fine but reverse. seems like it is not going into gear? i looked underneath and the lever does not seem to move very far...maybe about an inch? i tried the whole loosen the cover and tap upward deal with no luck. i got on it with a wrench and gave it some grunt...still no luck. please help
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928366
02/14/11 12:00 AM
02/14/11 12:00 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Take the side cover off and see if it will engage reverse. If it does smoothly, then you need to have a hard look at the 1/2 lever. It might be binding the reverse lever. I have had some that just wouldn't fit-even pushing the cover up to the limit. Put a different 1/2 lever in the cover and it worked fine.
MB
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: HPMike] #928367
02/14/11 12:16 AM
02/14/11 12:16 AM
kansas city, mo
kansas city, mo
are you talking about a 1/2 lever that is inside the case? i am new to 4 speeds.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928368
02/14/11 12:21 AM
02/14/11 12:21 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Yes, well technically it's in the side cover. The piece that the shaft of the shift fork goes into. There is a curved relief that the reverse gear arm rides very close to. If these pcs are incompatible, then you will have the issue you have.
Mb
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928369
02/14/11 12:29 AM
02/14/11 12:29 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Check the adjustment first. 1-2 and 3-4 have to be in neutral or the trans won't go into reverse. Might have to work the clutch a little to get it to go, or roll the vehicle slightly while trying to go into reverse. If you do not have the proper tool to lock the shifter in neutral you can make one from 1/4" round stock bent in the shape of an allen key.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: Sixpak] #928370
02/14/11 12:41 AM
02/14/11 12:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....also you might just try to disconnect the reverse rod from the shifter end, and see if the shifter can detent into the reverse position,....I once purchased a complete E body 4spd set-up from it's owner who removed it thinking the tranny was bad,...he swapped over to an automatic he was so distraught trying to solve the reverse engagement problem he was trying to troubleshoot,....turns out the thin shim plates located between each shifter lever, that allow the shifter plates to slide on each other was loose and bound it self up between the 1st/2nd and reverse shifter plate not allowing the reverse shifter lever to slide independant of the other shifter levers,...basically binding just the reverse shift position
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928371
02/14/11 12:43 AM
02/14/11 12:43 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
You need to make sure all gears are in neutral..
When they are the Hurst shifter lever will move smoothly left to right..
When the gears are all in neutral the shift arms should line up, some Hurst shifters have a hole that you can put a drill bit through. Next adjust the shift arms if needed when in neutral, if all is well then putting into reverse is EZ move the lever to the left and up..
Just my $0.02..
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: DAYCLONA] #928372
02/14/11 12:47 AM
02/14/11 12:47 AM
kansas city, mo
kansas city, mo
trying to move reverse tab on transmission in to "gear" with rod entirely disconnected. only moves about an inch.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928373
02/14/11 12:52 AM
02/14/11 12:52 AM
kansas city, mo
kansas city, mo
installed shifter and rods by the book. aligned by holes in neutral
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928374
02/14/11 12:55 AM
02/14/11 12:55 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You have to be 100% sure that the 1/2 and 3/4 shift levers are in their neutral position, even the slightest load on one of their levers from the shifter being not being adjusted properly will/might prevent you from engaging reverse,.....are you famaliar with the adjustment procedure?
Mike
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: DAYCLONA] #928375
02/14/11 12:59 AM
02/14/11 12:59 AM
kansas city, mo
kansas city, mo
i did it using an article that i found...i'll be dang if i cant find it now.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928376
02/14/11 01:11 AM
02/14/11 01:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just a quick question,...are all 3 arm levers, esp the reverse shift arm located on the transmission, have all their shifter rod button holes facing up/vertical?....in other words, are all the shift arms located on the tranny facing the same installed direction?...up
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: DAYCLONA] #928377
02/14/11 01:15 AM
02/14/11 01:15 AM
kansas city, mo
kansas city, mo
yes all up. not od trans followed this article to set up...very good for reference. http://www.moparmusclemagazine.com/howto...opar/index.html
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928378
02/14/11 01:21 AM
02/14/11 01:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Well you have a good source listed for the set-up procedure, and if you feel it was performed properly, ...Make sure the shifter can detent properly into reverse without the reverse rod attached,...if the shifter checks out fine,...your gonna have to open the side case to investigate further as to what is preventing the reverse from engageing
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928379
02/14/11 02:21 PM
02/14/11 02:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
You can rule out the shifter adjustment by disconnecting all the shifter rods from the trans. Make sure 1-2 and 3-4 are definitely in neutral - work the levers bolted to the side of the case til they are in neutral. Then try to manually put the trans into reverse using the bolted on lever. If it doesn't go try spinning the trans output shaft a little. If it goes into reverse you know you have a shifter adjustment problem, if not, then it's inside the trans.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: Sixpak] #928380
02/14/11 11:30 PM
02/14/11 11:30 PM
kansas city, mo
kansas city, mo
how to spin the input shaft while in car? ...turn it over or run engine with clutch out in neutral?
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928381
02/15/11 01:27 AM
02/15/11 01:27 AM
PENNSYLVANIA
GARAGEMAN Offline
GARAGEMAN  Offline
PENNSYLVANIA
Hey all. I had the same problem.The first and second shifter fork needs turned around. The reverve lever is hiting the trans fork thats why one is different than the other.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: GARAGEMAN] #928382
02/15/11 01:43 AM
02/15/11 01:43 AM
kansas city, mo
kansas city, mo
THANKS FOR THE INFO GUYS. I WILL TAKE IT TO THE TRANSMISSION GUY AND TELL HIM YOUR IDEAS. I AM AFRAID THAT IF I GET IN THERE MYSELF, I MIGHT JACK IT UP.
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: rave_12000] #928383
02/15/11 10:56 PM
02/15/11 10:56 PM
Minnesota USA
Dart6pak Offline
Dart6pak  Offline
Minnesota USA
From your desceiption it seems to me that your cover is not aligned properly.The clearance between the 1/2 and reverse is too close causing a binding. Before you take it to a shop try this. Loosen the cover bolts and put the trans in reverse--this will set the clearance --with the trans in reverse retighten the cover bolts .
Re: a 833 4 speed...no reverse or just out of adjustment? [Re: GARAGEMAN] #928384
02/16/11 05:52 PM
02/16/11 05:52 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
Thanks - I've been wondering why the two are different
