Re: 440-1 head user what roller lifters
[Re: earthmover]
#928194
02/13/11 11:05 PM
02/13/11 11:05 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
you can use straight lifters but the offsets clean up the pushrod angle some. Here is a pic:
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: B G Racing]
#928199
02/14/11 11:22 PM
02/14/11 11:22 PM
Posts: 16,928 NC
440Jim
NC
When using the offset lifters you may have to clearence the 4 casting lugs in the lifter valley near the block deck for pushrod clearence.
On a 400 low deck with Indy 440-1 offset intake rockers, this is what it looks like.
[Re: 440Jim]
#928200
02/16/11 05:55 AM
02/16/11 05:55 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Pictures are worth a thousand words
[Re: Cab_Burge]
#928205
02/16/11 09:33 PM
02/16/11 09:33 PM
Posts: 16,928 NC
440Jim
NC
My 440-1 heads on the low deck with non offset solid roller lifters didn't rub on the low deck block
Yes, we have been saying combining a low deck, 440-1 (or B1) offset rockers, and offset roller lifters. You didn't have all of them.
[Re: 440Jim]
#928206
02/16/11 11:22 PM
02/16/11 11:22 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Sometimes you get lucky and sometimes you don't I did notice on the 440 block that the 7/16 pushrods are very close to the block lugs. I forgot to mention, I think, that the low deck motor had 3/8 pushrods and the 440 motor has 7/16
[Re: moparniac]
#928212
02/26/11 10:44 AM
02/26/11 10:44 AM
Posts: 16,928 NC
440Jim
NC
Those pictures are good. So .485 lobe lift with your cams base circle and a bushed aluminum World block look fine with the IMM roller lifters. I think those are a great design. It looks like the top of the lifter is below the top of the lifter bore at zero lift. And the lifter sticks out roughly 3/8" at max lift.
