15 x 8 Steel Wheels - junk yard vehicles #928158
02/13/11 09:29 PM
02/13/11 09:29 PM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
i need some 15 x 8 steel wheels for my 65 b-body. what vehicles (non - mopar) would have these? i've read where ford wheels will not center on the hub of a mopar axle but wouldn't any aftermarket wheel be the same (non hub centered)? i have access to a good junk yard with a lot of older vehicles so any ideas would be great. i would also like to use the small diameter dog-dish type hub caps.
thanks
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Husker1] #928159
02/13/11 09:34 PM
02/13/11 09:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
OEM Ford wheels won't work because most used a smaller register diameter than Mopar.
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: DoctorDiff] #928160
02/13/11 09:41 PM
02/13/11 09:41 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
The only STEEL wheel is the 77/78 basically RamCharger/Trailduster and dodge trucks. All the others are 15x7. The 15x7 came on everything from Dippy's to Aspens.
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Devil] #928161
02/13/11 09:49 PM
02/13/11 09:49 PM
North Carolina, USA
Husker1 Offline OP
Husker1  Offline OP
North Carolina, USA
any other OEM wheel options? Dodge trucks 77-78 might be a possiblity? I know there are not any ramchargers at this yard but i have seen some 70's dodge trucks. When did dodge change the bolt pattern on the trucks?
thanks
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Husker1] #928162
02/13/11 09:52 PM
02/13/11 09:52 PM
Why not just get some from Summit?
They're pretty cheap, you can get a few different offsets, and virtually any width you want.
They're made by Wheel Vintiques.
Re: 15 x 8 Steel Wheels - junk yard vehicles #928163
02/13/11 10:07 PM
02/13/11 10:07 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
They were only on ramchargers.
Summit Racing has oe steel 15x8 by Wheel Vintiques for 85.95 ea plus 12.00 handling.
Moparts member Cab Burge has a pair on here as well,you might try contacting him.
John
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Husker1] #928164
02/13/11 10:57 PM
02/13/11 10:57 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
thanks
AFAIK, only Ramchargers with the 10.00x15 tire option had the 8"x15" wheels. I've always heard it referred to as the Ramcharger wheel but it should have been available on W100 at the same time. It's always been a hard to find wheel.
2wd bolt pattern went from 4.5 to 5.5 in '85.
4wd went from 5.5 to 4.5 in '75, then back to 5.5 in (I think)'80.
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: B5 Bee] #928165
02/13/11 11:23 PM
02/13/11 11:23 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
15x8 ramcharger wheels without centers 77 78 RC with 10 " tires
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Day2Runner] #928166
02/13/11 11:26 PM
02/13/11 11:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And Trail Dusters
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: 62maxwgn] #928167
02/13/11 11:36 PM
02/13/11 11:36 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
so sorry try again I dont think you may find any in a junk yard maybe swap meet these wheels have a 4,25 backset and some are drill for centers
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Day2Runner] #928168
02/14/11 10:46 AM
02/14/11 10:46 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
SuperCoupe 15x8" (cop style) rims, or 15x8" Ramcharger rims. Those are your options. You will find neither in a junkyard, unless you are literally the ONLY Mopar guy within 500 miles and have been asleep for 20 years.
I think you'd be better off just buying some new 15x8" steel rims from one ov the few vendors out there that make Mopar rims. I also think this would end up being cheaper than if you found some Ramcharger rims for sale somewhere. Last i checked they were NOT cheap rims to buy, and last i checked was a long time (and a lot ov crushed/recycled rims) ago...
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Husker1] #928169
02/14/11 01:25 PM
02/14/11 01:25 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
thanks
'85 IIRC, but 70's dodge trucks will have 15x6 or 15x6.5 rims
5th ave's and diplomats have 15x7's
2017 Grand Cherokee Overland
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: patrick] #928170
02/14/11 03:09 PM
02/14/11 03:09 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
As others have said, Ramcharger wheels are what you're looking for. When I see them at swap meets they are generally $100 each. For a few $$ more, Wheel Vintiques might be a better choice than old rims.
Be aware - Ramcharger wheels are HEAVY!
I don't thnik any Ford wheels will fit the later 'small' 9" hubcaps.
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Pale_Roader] #928171
02/14/11 03:10 PM
02/14/11 03:10 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Super Coupe rims don't have hubcap nibs, they fit centercaps only. Same for teh 15x7 Magnum GT wheel.
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Fury Fan] #928172
02/15/11 01:54 AM
02/15/11 01:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a set of Mopar 15 x 8 steelies that I want to sell. PM me if you are interested and want more info. Ron
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: DoctorDiff] #928173
02/15/11 11:49 PM
02/15/11 11:49 PM
at large
moparphillie Offline
at large
Why not contact the resident expert on Mopar wheels. His name is G. Franklin ( Frank ) Long III and he goes by the name of " The Wheel Guy ". Frank is located in Clinton, Indiana 47842 and his contact information is as follows:
Website: http://the-wheel-guy.com
Phone: ( 765 ) 832 2327
Fax: ( 765 ) 832 1173
E-mail: guy@the-wheel-guy.com
Frank is a great guy to work with and he always has a set of 15 x 8 Ramcharger wheels on hand and available FOR SALE.
Good luck...
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: moparphillie] #928174
02/18/11 02:01 PM
02/18/11 02:01 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I have been off Moparts for about a week and I find this thread. You are too kind , thanks....
Yes I have some 15 x 8 Ramcharger wheels for sale. I have some orginal wheels with the 4.25 backspace and some repop wheels with a 4.50 backspace. The 4.50 backspace works well on B and E bodies where as the 4.25 works well on A bodies that have been converted.
Some of the earlier B bodies like even more backspace , but I don't have any of those in stock at the moment.
PM me for more info.....
Frank
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: duster2] #928175
02/18/11 02:21 PM
02/18/11 02:21 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Don't forget Jeep wheels, but I don't think they had a 15x8 steel wheel. Lots of alloy options though.
AND, they're hub centric!
Re: 15 x 8 Steel Wheels - junk yard vehicles [Re: Montclaire] #928176
02/19/11 08:36 AM
02/19/11 08:36 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
As far as i've seen in my lengthy tenure climbing over mountains ov rims and sifting though warehouses ov wheels looking for cool/cheap stuff, there is no such animal as a 15x8 Jeep rim. Though it would be nice if someone here would prove me wrong... We need more welfare 8" rim options for Mopars.
