Pictures of BB turbo setup in stock engine compartment? #927892
02/13/11 03:20 PM
02/13/11 03:20 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I am looking to put a turbo on a BB in a early B body. Looking for placement and ideas!
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 65 Hemi] #927893
02/14/11 05:52 PM
02/14/11 05:52 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Click the link in my signature.
- Stu Harmon
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 65 Hemi] #927894
02/15/11 10:50 PM
02/15/11 10:50 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927895
02/15/11 10:53 PM
02/15/11 10:53 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927896
02/15/11 10:55 PM
02/15/11 10:55 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927897
02/15/11 11:01 PM
02/15/11 11:01 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927898
02/15/11 11:54 PM
02/15/11 11:54 PM
kentucky
roadrunner7020 Offline
kentucky
1967 satellite That looks great! where did you get or how did you fabricate the turbo to intercooler piping? how did you do the exhaust crossover? Looks amazing i plan on building a smallblock turbo challenger soon and if i could get a look half this clean id be ecstatic!
Re: Pictures of BB turbo setup in stock engine compartment? [Re: roadrunner7020] #927899
02/16/11 11:29 PM
02/16/11 11:29 PM
The pipes are totally fabricated to "fit" where they had to go.It had to meet 2 requirements,fit under the flat hood and not sacrifice the A/C compressor. Just used a variety of elbows and bends,a sawsall and welder.I wanted to increase the tube size right out of the compressor, but I had to clear the upper radiator hose,so it stayed 2 1/2" for a short run. This was the best compromise compared to running the tube down low and across. http://i355.photobucket.com/albums/r461/FriedDonuts/P1000750.jpg This is the crossover pipe. It runs from the driver side,which has what is essentially a copy of a high perf. factory manifold,to the log on the pass. side.
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927900
02/22/11 06:35 PM
02/22/11 06:35 PM
IL
furious70 Offline
furious70  Offline
IL
Do you have pics of the rest of the hotside, manifolds, merge, and downpipe?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 65 Hemi] #927901
02/24/11 08:47 PM
02/24/11 08:47 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Saw this on the vacation last year. Gramma fresh.
Re: Pictures of BB turbo setup in stock engine compartment? [Re: furious70] #927902
02/24/11 11:14 PM
02/24/11 11:14 PM
No, but since the eng./trans is still out I'll get some and post them after work tomorrow.
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927903
02/25/11 01:34 AM
02/25/11 01:34 AM
Borden, Indiana, U.S.A.
W
wrenchinrandy Offline
W
Here is a picture of another '67 B-body. This one is a Charger.
Re: Pictures of BB turbo setup in stock engine compartment? [Re: GwaiiEagle] #927904
02/25/11 12:23 PM
02/25/11 12:23 PM
IL
furious70 Offline
furious70  Offline
IL
That Coronet is on theturboforums, he's got a bunch of pics on there about how it went together, it's pretty cool.
http://www.theturboforums.com/smf/index.php?topic=140522.0
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927905
02/25/11 09:30 PM
02/25/11 09:30 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927906
02/25/11 09:31 PM
02/25/11 09:31 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927907
02/25/11 09:33 PM
02/25/11 09:33 PM
http://i355.photobucket.com/albums/r461/FriedDonuts/P1000755.jpg Pass side. I added a v band clamp for the crossover since it was out.
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927908
02/25/11 09:33 PM
02/25/11 09:33 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927909
02/25/11 09:34 PM
02/25/11 09:34 PM
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 67_Satellite] #927910
02/28/11 03:47 PM
02/28/11 03:47 PM
right here
1BADDUSTER Offline
1BADDUSTER  Offline
right here
LOOKS GOOD
Re: Pictures of BB turbo setup in stock engine compartment? [Re: 65 Hemi] #927911
02/28/11 10:33 PM
02/28/11 10:33 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
In an a-body
