Pictures of BB turbo setup in stock engine compartment?
#927892
02/13/11 03:20 PM
02/13/11 03:20 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I am looking to put a turbo on a BB in a early B body. Looking for placement and ideas!
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Pictures of BB turbo setup in stock engine compartment?
[Re: 65 Hemi]
#927893
02/14/11 05:52 PM
02/14/11 05:52 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Click the link in my signature.
[Re: roadrunner7020]
#927899
02/16/11 11:29 PM
02/16/11 11:29 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
The pipes are totally fabricated to "fit" where they had to go.It had to meet 2 requirements,fit under the flat hood and not sacrifice the A/C compressor. Just used a variety of elbows and bends,a sawsall and welder.I wanted to increase the tube size right out of the compressor, but I had to clear the upper radiator hose,so it stayed 2 1/2" for a short run. This was the best compromise compared to running the tube down low and across. http://i355.photobucket.com/albums/r461/FriedDonuts/P1000750.jpg This is the crossover pipe. It runs from the driver side,which has what is essentially a copy of a high perf. factory manifold,to the log on the pass. side.
[Re: 67_Satellite]
#927900
02/22/11 06:35 PM
02/22/11 06:35 PM
Posts: 2,255 IL
furious70
IL
Do you have pics of the rest of the hotside, manifolds, merge, and downpipe?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: joshking440]
#927912
03/01/11 11:29 AM
03/01/11 11:29 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
In an a-body
That is one of the baddest cars on the site, cant stop looking at it
