73 Roadrunner/ Satellite dash pad swap #926497
02/11/11 04:01 PM
02/11/11 04:01 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
My 73 Roadrunner dash pad is wasted I bought a cap for it but I think it's too wasted for a cap. My 73 Satellite parts car has a dash pad that's in better shape. How do the dash pads come off?
Re: 73 Roadrunner/ Satellite dash pad swap [Re: Boise Chall] #926498
02/11/11 05:08 PM
02/11/11 05:08 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I don't like the caps, many of them are junk. There are small nuts up inside the pad. You can get at them easy if the dash is off, but if it isn't take the seats out so you can lay on your back and get a deep dish socket up in there. You'll need small arms to get into the instument area.
Re: 73 Roadrunner/ Satellite dash pad swap [Re: DANA60] #926499
02/11/11 05:46 PM
02/11/11 05:46 PM
Boise Idaho
Boise Idaho
I was hoping for an easy way to do it but I guess I'll have to stop being lazy and get that dash off Like I should have in the first place. Thank you
Re: 73 Roadrunner/ Satellite dash pad swap [Re: Boise Chall] #926500
02/11/11 06:37 PM
02/11/11 06:37 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
It would be easier to try it while in the car before you go to all that trouble.
Re: 73 Roadrunner/ Satellite dash pad swap [Re: DANA60] #926501
02/11/11 06:42 PM
02/11/11 06:42 PM
Boise Idaho
Boise Idaho
I have the entire car stripped all interior and column except for the dash. For some reason I'm nervous about taking it out but I need to paint it anyway so I just need to get over it. I'm sure I will have some questions. I am painting the car the beginning of next week and will plan on pulling the dash out later next week.
Re: 73 Roadrunner/ Satellite dash pad swap [Re: Boise Chall] #926502
02/11/11 07:09 PM
02/11/11 07:09 PM
indiana
generallee6901 Offline
indiana
It is actually easier i think to pull the whole dash to change on the 71-74 b-bodies than to try and replace without the pad without removing the whole thing.
Re: 73 Roadrunner/ Satellite dash pad swap [Re: generallee6901] #926503
02/11/11 08:41 PM
02/11/11 08:41 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
If you're planning on taking out the whole dash - do it before removing the pad. You can take the pad off without removing the whole dash first, but your arms will look like you've been in a fight with the cat! Those nuts in back and on the sides are not fun.
Re: 73 Roadrunner/ Satellite dash pad swap [Re: Boise Chall] #926504
02/12/11 12:42 AM
02/12/11 12:42 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I think its easier to pull the dash too. On '73's, its really not too hard.
Here's a how to from the archives: dash removal
John
