Enclosed trailer has small leak #926183
02/11/11 12:08 PM
02/11/11 12:08 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
I have a haulmark elite 2 with the fiberglass/plastics cap on the top of the front I huess to help with the aero of it. Anyways I opened the trailer up for the first time in a few months and I had water streaks down the front and the floor had a little water standing looks to be coming from around that cap. What is the best thing to re-seal the roof of a trailer? It is a 2000 model and has never been re-done that I can tell. thanks
One day I will have something cool here.
Re: Enclosed trailer has small leak [Re: sdaurity] #926184
02/11/11 04:07 PM
02/11/11 04:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They make a gray colored stuff that goes on real heavy. I don't know what it is or called.
When I took my RV back to the manufacturer in Middlebury Ind, near Elkhart, they asked if I ever resealed to the roof. I said no and it wasn't leaking. They said it was standard practice to reseal the seams from time to time. When I got it back there was a fresh coat of something thick and gray on all the roof seams.
That's all I got, the seams do move a little when the trailer is going down the road, so I'm guessing something flexiable.
Re: Enclosed trailer has small leak [Re: Challenger 1] #926185
02/11/11 04:14 PM
02/11/11 04:14 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I use the white mobile home stuff from Home Depot and do the whole roof. It also being white makes the trailer cooler inside. Just clean the roof and then roller it on.
Re: Enclosed trailer has small leak [Re: poisondart2] #926186
02/11/11 05:17 PM
02/11/11 05:17 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I brought mine from Wal-Mart & put it on the top with a roller. A 5 gal. bucket was only about $40.00 it is a plastic fiber coat for roofs(I think they used it on the old tin roofs)but it works.I can't remember the name either but you get it in the paint section.Get you a roller open the 5 gal. bucket dip the roller in the bucket & roll it on"Simple"
It took about 30 mins. to do the top of my 40' GN trailer.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Enclosed trailer has small leak [Re: MRMOPAR622] #926187
02/11/11 05:27 PM
02/11/11 05:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
I wouldn't do the whole thing, just the seams. Why add all the weight and risk having it lift off down the road someday or while your going down the road. Every pound counts on a trailer just like race cars.
My roofs have been one peice aluiminum with seams on the edges. I get up on my roofs and wash em at least once a year, that helps keep the black streaks from running down the side of my trailer. Having all that coating up there would be hard to keep clean and who knows what's gonna run down the sides then.
Re: Enclosed trailer has small leak [Re: Challenger 1] #926188
02/11/11 05:34 PM
02/11/11 05:34 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Thanks for the replys. One of my buddys had said to use tar roof sealer? I will check on the mobile home roof coating tonight and check to see what wal-mart has.
Re: Enclosed trailer has small leak [Re: sdaurity] #926189
02/11/11 05:40 PM
02/11/11 05:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
I'd advise shopping at a RV store, they will have the right stuff. Not the stuff you put on top of mobile homes, that's not what I'm talking about.
You don't want any tar on the roof of your race car trailer, I'm telling you.
Re: Enclosed trailer has small leak [Re: Challenger 1] #926190
02/11/11 05:46 PM
02/11/11 05:46 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Calling the RV shop as we speak.
Re: Enclosed trailer has small leak [Re: Challenger 1] #926191
02/11/11 05:48 PM
02/11/11 05:48 PM
Winnipeg, Canada
StrokerDart Offline
StrokerDart  Offline
Winnipeg, Canada
I think the name of that grey stuff is Siliprene
Re: Enclosed trailer has small leak [Re: StrokerDart] #926192
02/11/11 06:03 PM
02/11/11 06:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
It's something that self levels and then get's hard. I've only seen it on the roofs of RVs and race car trailers.
Re: Enclosed trailer has small leak [Re: sdaurity] #926193
02/11/11 06:26 PM
02/11/11 06:26 PM
Locomotion Offline
Locomotion  Offline
I used some stuff called Geoguard quite a few years ago and haven't had any leaks yet. I believe it's an industrial roof patch, It goes on over a matting and I did the seams all around the aluminum roof and vents. The down side is that it's pretty expensive and the shelf-life isn't too long.
Yea, forget the tar, unless you want tar streaks down the side of the trailer in the summer.
Re: Enclosed trailer has small leak [Re: Locomotion] #926194
02/11/11 08:15 PM
02/11/11 08:15 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I may be wrong but I think the name may be "Kool Seal". It dries but looks like its flexible,don't think it will ever come lose and blow off it might in pieces like paint. I would not think it would be all that heavy,but it might. It also helps keep the trailer cooler inside. It does do a good job of stopping small leaks,and will not run off like tar.
PS Make the top look like new again.
Re: Enclosed trailer has small leak [Re: MRMOPAR622] #926195
02/11/11 10:40 PM
02/11/11 10:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Go to a tractor-trailer repair shop - they sell a urethane sealer for just this purpose. Sticks to anything, dries but stays pliant so it won't crack, stinks like hell for a few days. Comes in clear and a couple other colors.
